Re: Build Dates on Fender Tag Versus Vin Number Sequence?
[Re: blewbyu]
#1657390
08/11/14 11:35 AM
08/11/14 11:35 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Does this mean it took a lot longer to build my car?
The VIN is assigned when the order is placed I am pretty sure , not when the car finally hits the assembly line.
Are the 2 build dates you mention for cars built at the same plant ?? Same year ???
[Re: JohnRR]
#1657393
08/11/14 03:20 PM
08/11/14 03:20 PM
Posts: 4,283 Florida
blewbyu
Different plants and different model cars but the same year cars, both are 69 models
[Re: blewbyu]
#1657394
08/11/14 04:12 PM
08/11/14 04:12 PM
JohnRR
U.S.S.A.
You can't compare them then.
You can only compare cars built at the same plant durning the same model year , models of the same platform don't matter , nor does dodge vs. plymouth on the same platform ... ie: a B body
[Re: blewbyu]
#1657395
08/11/14 05:05 PM
08/11/14 05:05 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
1969 a & b-body assembly plants:"A" - Lynch Rd. Detroit, MI built ~215,000 cars - R & W b-body lines "B" - Hamtramck, MI built ~355,000 cars - a-bodies & Chargers "E" - Los Angeles, CA built ~72,000 cars - a-body and R & W b-body lines "G" - St. Louis, MO built ~310,000 cars - R, W & X b-body lines "R" - Windsor, ONT built 172,000+ cars - a-body & c-body St. Louis plant WM2xx9G240xxx w/SPD 326 Hamtramck plant LS23M9 B344xxx w/SPD 329 (best guess w/o more info, your car was actually assembled a week later on or about Friday, 4/4/69) What's the date on your K-frame and/or your engine's EAD? What's the "SEQUENCE #" upper left of your b'cast sheet?The 1969 A12 & A13 "program" cars had "make believe" SPD dates & their VINs were not assigned until the plant actually scheduled its build. IMO your car didn't take any longer to build.
[Re: 6bblgt]
#1657396
08/11/14 11:01 PM
08/11/14 11:01 PM
blewbyu
1969 a & b-body assembly plants: "A" - Lynch Rd. Detroit, MI built ~215,000 cars - R & W b-body lines "B" - Hamtramck, MI built ~355,000 cars - a-bodies & Chargers "E" - Los Angeles, CA built ~72,000 cars - a-body and R & W b-body lines "G" - St. Louis, MO built ~310,000 cars - R, W & X b-body lines "R" - Windsor, ONT built 172,000+ cars - a-body & c-body
St. Louis plant WM2xx9G240xxx w/SPD 326 Hamtramck plant LS23M9A344xxx w/SPD 329 (best guess w/o more info, your car was actually assembled a week later on or about Friday, 4/4/69) What's the date on your K-frame and/or your engine's EAD? What's the "SEQUENCE #" upper left of your b'cast sheet?
My Engine assy was 3/26 on the top engine pad and on build sheet seq# is 1173150 assy plant B, the other was assy plant G
[Re: blewbyu]
#1657397
08/11/14 11:59 PM
08/11/14 11:59 PM
6bblgt
Las Vegas, NV
I have a copy of a sheet from: LS23H9B350342 SPD 411 & SEQUENCE NUMBER 1 171197LS23M9B344xxx SPD 329 & SEQUENCE NUMBER 1 173150Based on the b'cast sheet's sequence number your car was started ~2000 cars (only a few days) after the 383 GTS. I just do NOT have enough info to figure if that's later than my 4/4/69 "guesstimate" or the above 383 GTS was a week early. K-frame date would help if available. The LS23H9B350342 sheet was in LS23M9B341723 another 329 SPD 440 Dart GTS.
[Re: 6bblgt]
#1657398
08/12/14 12:42 AM
08/12/14 12:42 AM
blewbyu
I have a copy of a sheet from: LS23H9B350342 SPD 411 & SEQUENCE NUMBER 1 171197 LS23M9B344xxx SPD 329 & SEQUENCE NUMBER 1 173150
I can get the k frame info tomorrow
[Re: Cab_Burge]
#1657403
08/12/14 03:46 PM
08/12/14 03:46 PM
blewbyu
I'm curious as to where to look at my 1969 GTS K member for a date code, it's a H code car. Mine is not numbers matching, way to many owners and way to many years of racing it
Look on the front face of the K frame that faces the bumper
