O2 Sensor #1656946
08/10/14 10:30 AM
08/10/14 10:30 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Scanner said bank one sensor one on my truck. I replaced and it went off but the service engine light came on again after two days and scanned again same sensor. Any ideas what is going on. The truck runs fine but something is setting it off. Thanks
Re: O2 Sensor [Re: 70 buzz] #1656947
08/10/14 12:34 PM
08/10/14 12:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Remember that the code is for that circuit, not just the sensor. Was the replacement sensor the same brand as the one removed?
It might be a good idea to test the old sensor and the new one to see how their outputs compare.
Master, again and still
Re: O2 Sensor [Re: 70 buzz] #1656948
08/10/14 02:05 PM
08/10/14 02:05 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
yes the same
Re: O2 Sensor [Re: 70 buzz] #1656949
08/10/14 02:34 PM
08/10/14 02:34 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Pre or post cat?
Re: O2 Sensor [Re: jbc426] #1656950
08/10/14 02:59 PM
08/10/14 02:59 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Pre or post cat?
upstream which would be pre cat
