Re: O2 Sensor
[Re: 70 buzz]
#1656947
08/10/14 12:34 PM
08/10/14 12:34 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Remember that the code is for that circuit, not just the sensor. Was the replacement sensor the same brand as the one removed?
It might be a good idea to test the old sensor and the new one to see how their outputs compare.
Master, again and still
Re: O2 Sensor
[Re: 70 buzz]
#1656948
08/10/14 02:05 PM
08/10/14 02:05 PM
Posts: 1,893 michigan
70 buzz
michigan
Scanner said bank one sensor one on my truck. I replaced and it went off but the service engine light came on again after two days and scanned again same sensor. Any ideas what is going on. The truck runs fine but something is setting it off. Thanks
yes the same
Re: O2 Sensor
[Re: jbc426]
#1656950
08/10/14 02:59 PM
08/10/14 02:59 PM
70 buzz
michigan
Pre or post cat?
upstream which would be pre cat
