Coupe Windows 1968 to 1970 B-Body True or False? #1656539
08/08/14 10:29 PM
08/08/14 10:29 PM
Brantford Ontario
69_SIX_PACK Offline OP
Brantford Ontario
Are they the same or different?
I am talking the pop out windows kind...are they the same on a Dodge and Plymouth 1968 to 1970 b-body?
Does anyone have pics of the two?
Thanks!
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656540
08/08/14 10:48 PM
08/08/14 10:48 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Dodge and Plymouth are different , Dodge is smaller in length front to back
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: JohnRR] #1656541
08/08/14 10:56 PM
08/08/14 10:56 PM
Brantford Ontario
Brantford Ontario
Thanks John, is there a way to tell them apart by looking at them?
Are the coupe "posts" different on the cars? Is that why they are different.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656542
08/09/14 12:14 AM
08/09/14 12:14 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
It's the "bulge" in the upper body line of the quarter panel that causes the Dodge glass to be smaller.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656543
08/09/14 01:13 AM
08/09/14 01:13 AM
JohnRR Offline
JohnRR  Offline
yes , got a tape measure ?
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: JohnRR] #1656544
08/09/14 01:21 AM
08/09/14 01:21 AM
Brantford Ontario
Brantford Ontario
sure now give me some dimensions so I know what to look for.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656545
08/09/14 01:25 AM
08/09/14 01:25 AM
Brantford Ontario
Brantford Ontario
I am not sure what you mean. Hardtop glass is the same between the Dodge and Plymouth though right?
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656546
08/09/14 02:00 AM
08/09/14 02:00 AM
JohnRR Offline
JohnRR  Offline
Oddly yes it is , I put the rear quarter glass from a charger in my 69 RR.
As far as the dimension , measure your car , Plymouth is 2" longer.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: JohnRR] #1656547
08/09/14 04:46 PM
08/09/14 04:46 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
The hardtop glass is the same because the excess can stay below the belt-line. A coupe's quarter glass has to "pop" out past the quarter panel. I can get dimensions later today.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656548
08/09/14 08:12 PM
08/09/14 08:12 PM
Brantford Ontario
Brantford Ontario
I understand now, thanks
If you could get the measurements that would be great.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656549
08/10/14 03:30 AM
08/10/14 03:30 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656550
08/10/14 03:31 AM
08/10/14 03:31 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
~ 3/4" difference
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656551
08/10/14 03:34 AM
08/10/14 03:34 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
The Plymouth lower edge appears to be a straight line VS. the Dodge's being a compound curve.
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656552
08/10/14 11:24 AM
08/10/14 11:24 AM
Brantford Ontario
Brantford Ontario
That's awesome, thank you
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 6bblgt] #1656553
08/10/14 11:29 AM
08/10/14 11:29 AM
JohnRR Offline
JohnRR  Offline
~ 3/4" difference
What's an 1.5" between friends ???
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: JohnRR] #1656554
08/10/14 11:48 AM
08/10/14 11:48 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
~ 3/4" difference
it's my understanding it's all about girth....
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: mikemee1331] #1656555
08/10/14 04:18 PM
08/10/14 04:18 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmmm... just a question, not glass related... this would mean the upper interior panels are not interchangeable either right ?
what other parts could be related to this difference ?
I'm asking this because IT SEEMS a friend of mine found "locally" ( actually in Colombia but close to the border, and he lives in Venezuela close to the border ) a 69 RR 4 speeds with B post what could buy, maybe could be the only one running in Venezuela soon, and will need lot of parts
Sorry the highjack!
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1656556
08/11/14 09:05 AM
08/11/14 09:05 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Son of a B. (no pun intended).
I never would have known they were not the same!
Then again, I'm not a B-body guy...
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: Commando1] #1876053
07/22/15 08:18 PM
07/22/15 08:18 PM
Brantford Ontario
Brantford Ontario
Did Road Runner have two different "pop out window" assemblies? One longer than the other?
Re: Coupe Windows 1968 to 1970 B-Body True or False? [Re: 69_SIX_PACK] #1876062
07/22/15 08:26 PM
07/22/15 08:26 PM
Brantford Ontario
Brantford Ontario
Hard to tell in the pics but the shorter window has its own screw hole, the longer one fits into a slot.
Hopefully you can see it in the pics.
