1971 cuda 383 kickdown photo? #1656194
08/07/14 07:45 PM
08/07/14 07:45 PM
kansas
johngeery Offline OP
kansas
I have a 1971 cuda 383 with correct intake and throttle bracket.
I cannot find a good image of the kickdown bracket, or for that matter-a driver's side engine photo with the air cleaner off.
I think the kickdown is one-piece, but unsure about that.
can anyone help?
thanks in advance-
john
Re: 1971 cuda 383 kickdown photo? [Re: johngeery] #1656195
08/07/14 08:53 PM
08/07/14 08:53 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
71 did use the one piece throttle pressure (kick down) linkage for the transmission. There are two different brackets, one for 383, and one for the 440. The bottom one in this pic is correct for a 71 383. Top one is 440.
Re: 1971 cuda 383 kickdown photo? [Re: T2R9] #1656196
08/07/14 08:56 PM
08/07/14 08:56 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
This pic is of the linkage installed from the drivers side. This is a 440 setup but the 383 will be typical.
Re: 1971 cuda 383 kickdown photo? [Re: T2R9] #1656197
08/08/14 02:00 AM
08/08/14 02:00 AM
kansas
kansas
Ok, thank you. That is the bracket I have. But I'm missing the cotter-pin thing. How many levers does it have? I assume just 2, lower one for the throttle cable and upper one for the kickdown. Know of anywhere that I can get this piece?
Thank you for your help
Re: 1971 cuda 383 kickdown photo? [Re: johngeery] #1656198
08/08/14 07:57 AM
08/08/14 07:57 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
It is a single lever shaped like a U connecting both. I have a setup off a car that I can get a picture of all the individual parts for you when I get home from work.
Re: 1971 cuda 383 kickdown photo? [Re: T2R9] #1656199
08/08/14 11:59 AM
08/08/14 11:59 AM
kansas
kansas
Outstanding. I appreciate it. 72 rallye charger?
Any idea about the stripes on the side of the green charger in the original gone in 60 seconds? The one that gets the dump truck to roll over on it. Surely those aren't factory stripes?
Re: 1971 cuda 383 kickdown photo? [Re: johngeery] #1656200
08/08/14 04:38 PM
08/08/14 04:38 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
That pic is my 72 Rallye, I dont recall the green charger, pics?
These are the three parts connecting the bracket, carb, and rod going down to the trans.
Re: 1971 cuda 383 kickdown photo? [Re: T2R9] #1656201
08/08/14 04:41 PM
08/08/14 04:41 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Assembled minus the bracket. Note the bracket to the carb shown here is a small block one. 383 is similar to the one on the car above. The lever and bracket that bolts to and adjusts the throttle pressure are the same.
Re: 1971 cuda 383 kickdown photo? [Re: T2R9] #1656202
08/08/14 06:17 PM
08/08/14 06:17 PM
kansas
kansas
DYNOmite!
thanks again, much appreciated.
here is the charger, maybe a 71 go green?
the stripe is a mystery
Re: 1971 cuda 383 kickdown photo? [Re: johngeery] #1656203
08/08/14 06:35 PM
08/08/14 06:35 PM
kansas
kansas
here is another
