Re: .150 needle and seats sealing????
[Re: ajcasini]
#1655464
08/05/14 10:09 PM
08/05/14 10:09 PM
Posts: 312 illinois
dodgeram1998
illinois
Valve lapping compound ? Or just dont waste the time and get the blp titanium eh ?
Thanks for the feedback I am about to pull my hair out on a simple needle Change out . R&R and troubleshoot two hours later lol which floats are rated also for the application?
[Re: ajcasini]
#1655465
08/05/14 11:22 PM
08/05/14 11:22 PM
Quicktree
I have always had problems with quick fuel and holley larger needle and seats. If you don't lap them they never seal. What I have done is switched to blp titanium n&s for all my builds. The .140 is perfect for e85 carbs. That is what I use on the majority of builds. I will go bigger when the demand is there for carbs over 1250 and up.
I am having the same dang thing happening with my quickfuel 950, thats why I was thinking about letting you do my dominator at some point. can you explain lapping them in? are you talking about the needle and seat bore?
[Re: dodgeram1998]
#1655466
08/05/14 11:24 PM
08/05/14 11:24 PM
Quicktree
I know the feeling I changed regulators,fuel pump,floats trying to find it
[Re: Quicktree]
#1655467
08/05/14 11:30 PM
08/05/14 11:30 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
had float problems with our 950 QFT E85 carbs...had to change out brand new needle and seats for the Titanium needle and seat on one of the carbs to get the float level stop creeping..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: mopar dave]
#1655471
08/05/14 11:49 PM
08/05/14 11:49 PM
Posts: 686 PA
ajcasini
PA
i have simular problem on a dominator with BLP .160 ns. 7psi or more and they dont seal, but i should be fine with 6psi anyway.
With the 160 I wouldn't think you would need much over 5.5psi. Unless fuel demand are extremely high on your combo. With the 140 I normally run 6-6.5lbs at the most.
