fuel pressure #1654715
08/03/14 10:30 PM
08/03/14 10:30 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Got the fuel pressure gage installed on the demon and the car is running a Edelbrock run quiet electric pump with a built in regulator. It had 3 psi at the carbs and we moved it up to 6.5. What are most of you running?
Re: fuel pressure [Re: maxie] #1654716
08/03/14 10:40 PM
08/03/14 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a KNOWN calibrated gauge a Holley will
take 7.5 PSI.. it MIGHT go 8 PSI without blowing the
needle off the seat... I run 7-7.5 psi... the AFB
style take a lot less
Re: fuel pressure [Re: maxie] #1654717
08/03/14 10:41 PM
08/03/14 10:41 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
6-7 pounds
1.39 9.85 - 137 mph
Re: fuel pressure [Re: maxie] #1654718
08/03/14 11:38 PM
08/03/14 11:38 PM
With the smaller volume pumps I push the pressure up to as much as the needles wil take to blow them off and then lower the prssure down 1/2 to 1.0 lbs On the bigger volume pumps I'm running 5.5 to 7.0 lbs, they both work
Re: fuel pressure [Re: Cab_Burge] #1654719
08/04/14 12:25 AM
08/04/14 12:25 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I used to run the mechanical and the electric pump, but took the mechanical off. I was surprised to see the pressure that low. I am still running the 3/8 line on the car.
Re: fuel pressure [Re: Cab_Burge] #1654720
08/04/14 12:27 AM
08/04/14 12:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Eddys will flood at much over 6.5PSI. I run 6.5 no issue with starvation.
Doug
Re: fuel pressure [Re: dvw] #1654721
08/04/14 12:46 AM
08/04/14 12:46 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
It has holley 4160 770 carbs on it
Re: fuel pressure [Re: maxie] #1654722
08/04/14 12:54 AM
08/04/14 12:54 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Forgot I also got the custom made covers for it also.
Re: fuel pressure [Re: maxie] #1654723
08/04/14 12:56 AM
08/04/14 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
7 psi is realistic with a good gauge.. also you MIGHT
want to increase the needle/seat more than the .110
if you need it
Re: fuel pressure [Re: maxie] #1654724
08/04/14 01:03 AM
08/04/14 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your covers can be screwing up the inlet air.. do you
have a radiused inlet under them and what is the mesh..
it might be too small for good flow
Re: fuel pressure [Re: MR_P_BODY] #1654725
08/04/14 10:09 PM
08/04/14 10:09 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
It has the A and A velocity stacks on it that are repops of the original ones. The mesh is a cover made for velocity stacks or air filters, a pre filter if you will. I just have them on there for street duty. They were custom made to the dimensions I needed.
Re: fuel pressure [Re: maxie] #1654726
08/04/14 11:53 PM
08/04/14 11:53 PM
gregsdart Offline
gregsdart  Offline
With four needle and seats feeding the motor, the pressure can be a lot lower. It shouldn't take over 4 psi as long as the regulator is by the carbs. I had a system many years ago that dropped to 3 psi with two 800 Holleys feeding about 600 hp, never went lean.
Re: fuel pressure [Re: gregsdart] #1654727
08/05/14 12:29 AM
08/05/14 12:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I set mine at 6 psi with an 850 DP. Ron
Re: fuel pressure [Re: 383man] #1654728
08/05/14 11:03 AM
08/05/14 11:03 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Mine is set at 5-5.5 lbs as per Bob Book and I have a Magna Fuel 500.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
