Superbird Engine Fire Restoration help #1654530
08/03/14 05:31 PM
08/03/14 05:31 PM
Lowell Mi
Rat_Exterminator Offline OP
Lowell Mi
Left my 6pk Bird, idling outside while I ran into office and 5 minutes later a delivery guy came in to tell me my RR was on fire. apparently there was a fuel leak from somewhere that ignited and was burning away. Put it out with fire extinguisher and called my insurance co. Unfortunately it was about 6 days before they could get an adjuster there during which time residue from extinguisher started corroding bare metal. There were very fair with paint estimate, pulling engine, repaint engine compartment, hood, blending into nose and fenders but I need some help with sources and pricing on the following as I intend to do most of the assembly other than paint myself.
Restore carbs (again) Promax? $1200?
Restore wiper motor (again) $400?
Restore alternator
Media blast and repaint air breather
CA332 Filter $150
Engine Harness (evans) $100
Forward light harness evans $100
Trans to firewall harness?
Reanodize voltage reg bracket?
Bulkhead connector?
Positive & neg battery cables?
Other than carbs and wiper motor, they gave me $500 and I think they are quite a bit short here, Thanks for your help, Greg
Re: Superbird Engine Fire Restoration help [Re: Rat_Exterminator] #1654531
08/03/14 05:49 PM
08/03/14 05:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Restore alternator
CA332 Filter $150
Bulkhead connector?
on the carbs, i'd would give Scott Harms a shout. he's on here all the time. I've seen pics of his work and they are top notch!
Re: Superbird Engine Fire Restoration help [Re: mikemee1331] #1654532
08/03/14 06:15 PM
08/03/14 06:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks for that Mike
Restore carbs (again) Promax? $1200? - www.harmsauto.com $799.00
Restore wiper motor (again) $400? Bruce Somer somerbr1@aol.com
Restore alternator - Jim Ridge-Dixie Restorations (803) 924-6247. Call for a quote depends on damage
Media blast and repaint air breather - A paint pro to do it right, likely $300 or so
CA332 Filter $150.00 or so is close for a reproduction, $400-500.00 for an NOS one. Try ebay
Trans to firewall harness? $100
I'd get all wiring from M&H harness (Year One 800-932-7663) probably double the price (or more) but the best I've seen.
Reanodize voltage reg bracket? Bulkhead connector?
J&S Restoration 412.295.1333 (contact for a quote)
Positive & neg battery cables? Frank Badelson sixpackfrank@aol.com
Re: Superbird Engine Fire Restoration help [Re: Rat_Exterminator] #1654533
08/03/14 07:39 PM
08/03/14 07:39 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
My 6 pak Bird caught fire in 1975 from a fuel leak that caused fuel to collect under the manifold and ignite. Check your hood carefully, it might be warped (mine was), very difficult to see until you paint it and you see it is wavy, alert your body man to look for this, also check your fender scoops,the rear edge of the fender scoop will droop, they are only plastic and it doesn't take a lot of heat to start deforming.
Re: Superbird Engine Fire Restoration help [Re: sixpackbird] #1654534
08/03/14 08:11 PM
08/03/14 08:11 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
That stinks. Sounds like you were lucky to catch it quick.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Superbird Engine Fire Restoration help [Re: 71TA] #1654535
08/03/14 11:16 PM
08/03/14 11:16 PM
Lowell Mi
Lowell Mi
Thanks all, I WAS lucky to catch it quickly. and it was fuel laying below the intake manifold too. Scott, I knew you were the go to it guy on hemi stuff but didn't realize you;d stoop to lowly 440 stuff LOL. Can I bring carbs to you at Nationals next week? or does that create transport problems for you? Turn around time? I had about a 4" diameter blister on top of the hood, nothing major so there shouldn't be warpage hopefully but I'll check. Thanks. Good reminder to all of us why we need to carry fire extinguishers, no doubt.
Re: Superbird Engine Fire Restoration help [Re: Rat_Exterminator] #1654536
08/03/14 11:44 PM
08/03/14 11:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Funny, I probably restore more of those pesky 6 packs than anything else
I won't be at the Nats, but couldn't get them on the plane home anyway so shipping is the way to go. Current turn time is about 6 weeks. Box each in a small box by itself, then pack all 3 tightly in a single bigger box, include your contact info inside. Toss in your linkage and other tarnished small plated parts and I'll do them at no added cost. USPS, FedEx, or UPS are fine, address is on my site, no payment due until completed.
Re: Superbird Engine Fire Restoration help [Re: ScottSmith_Harms] #1654537
08/04/14 12:40 AM
08/04/14 12:40 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
I have a 6 Pack Bird, too. I had Holley did the carbs. DISAPPOINTING, Color and warped base plate.! All American Barb in Florida is a great choice, too!
Did you have Repop Harnesses on car when it caught fire?
Ironically, I have a 65 Coronet Convert I am building/built. Evans Harnesses originally.
Got the Engine Bay detailed and all running well!
Let it idle for about 15 mins then took for a drive.
Car caught on fire and did the same damage as yours.
I had blamed the situation of possible mel;ting of Holly Plastic Sight Plugs....(Ethanol)
Nevertheless, I bought harnesses from MH (Year One) this time.
Don;t know the exact cause but I am eliminating possibilities.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: Superbird Engine Fire Restoration help [Re: 440PURSUIT] #1654538
08/04/14 12:55 AM
08/04/14 12:55 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Thanks Scott
Restore wiper motor (again) $220 plus shipping unless the internals are toast.I can also throw the reg bracket in with the rest of the plating. Bruce Somer somerbr1@aol.com
NS1AAR
Re: Superbird Engine Fire Restoration help [Re: Rat_Exterminator] #1654539
08/04/14 07:00 PM
08/04/14 07:00 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Everyone might consider obtaining Halon extinguisher instead powder and other types. Much easier post fire cleanup and likely corrosion damage to what's left
Re: Superbird Engine Fire Restoration help [Re: Sxrxrnr] #1654540
08/04/14 08:45 PM
08/04/14 08:45 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
Are Halon fire extinguishers allowed to be sold in Ca?
Re: Superbird Engine Fire Restoration help [Re: dilvoy] #1654541
08/04/14 09:29 PM
08/04/14 09:29 PM
N.Y.
sixpacksteve Offline
N.Y.
First i would thank the delivery guy. second, be glad thats All that happened! third be thankful there are guys like Scott etc.. to do the work that fast! Good luck on your repair
Hell Hath No Fury Like Mine
Re: Superbird Engine Fire Restoration help [Re: dilvoy] #1654542
08/05/14 05:13 AM
08/05/14 05:13 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Everyone might consider obtaining Halon extinguisher instead powder and other types. Much easier post fire cleanup and likely less or zero corrosion damage to what's left
Amazingly yes. Don't tell anyone as the nutcases in Sacramento will likely find an excuse to either tax or ban them. Of course with not a clue as to what they are or why someone would use one.
Re: Superbird Engine Fire Restoration help [Re: Sxrxrnr] #1654543
08/06/14 01:38 AM
08/06/14 01:38 AM
People's Republic of Kali
70runner Offline
70runner  Offline
My next door neighbor was a retired county fire chief. Very first thing he asked me after I restored my RR "where is the Halon fire extinguisher?" Shortly after that, I used his contacts to buy one.
About a year later we were in a mopar caravan to local show and a friends 69 Charger RT started smoking from the hood. Quickly pulled over and I used my Halon to put it out. I've got some pix somewhere, but there was very little damage - from the fire or extinguisher.
These are now in ALL my vehicles.
Re: Superbird Engine Fire Restoration help [Re: ScottSmith_Harms] #1654544
08/07/14 02:03 AM
08/07/14 02:03 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
And this is why Scott is awesome and others aren't.
Chris from New Jersey
Re: Superbird Engine Fire Restoration help [Re: fig426] #1654545
08/07/14 09:30 PM
08/07/14 09:30 PM
Lowell Mi
Lowell Mi
Scott is awesome in the way he shares his vast knowledge with everyone here, not just the popular guys. In addition to providing a great service at good prices. If I can help support his business and keep him in the mopar hobby instead of flipping burgers for Ray Croc, its a win win. Thanks Scott for all you do! Greg
PS is the 6 week turnaround from the time we talk about it or from when I get them to you ?
Re: Superbird Engine Fire Restoration help [Re: Rat_Exterminator] #1654546
08/07/14 09:55 PM
08/07/14 09:55 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Quick Fuel did my six pack carbs they turned out very nice and ran great.
Re: Superbird Engine Fire Restoration help [Re: PHJ426] #1654547
08/07/14 10:55 PM
08/07/14 10:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'll get them back to you ASAP, it will vary a bit based on the condition they arrive in, damaged or missing parts can string things out a bit. Here is a set I just did that took 10 weeks.....but it's easy to see why (right?).
Re: Superbird Engine Fire Restoration help [Re: ScottSmith_Harms] #1654548
08/07/14 10:56 PM
08/07/14 10:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
But the outcome was good in the end.
Re: Superbird Engine Fire Restoration help [Re: ScottSmith_Harms] #1654549
08/07/14 11:53 PM
08/07/14 11:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You're getting slow like me !!
