91 dakota front hub #1654472
08/03/14 02:55 PM
08/03/14 02:55 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
Found a project truck for my son and I to work on but need to know what you guys are doing with the six lug front hubs.Need to change them to 5 on 4.5 thanx for any help
Re: 91 dakota front hub [Re: mhead] #1654473
08/03/14 03:35 PM
08/03/14 03:35 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
It will interchange with an earlier (87-90) hub and rotor, 5 lug/4.5", the front is the easy part ...
It takes gasoline to interest me.
Re: 91 dakota front hub [Re: VL21] #1654474
08/03/14 06:20 PM
08/03/14 06:20 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
Well thats easy.I have a extra abody 83/4 housing was planing for the rear but dont know if its wide enough.Maybe a ford 8.8 would be a better choice being I dont have a center section.
Re: 91 dakota front hub [Re: mhead] #1654475
08/03/14 06:59 PM
08/03/14 06:59 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Easiest is to swap axels and brake drums to five lug. No plumbing to change, no drive shafts to mess with! no ubolts to buy, or braking bias change. It takes about an hour to pull the cover and r and r the axel assemblies.
Re: 91 dakota front hub [Re: moparpollack] #1654476
08/03/14 09:03 PM
08/03/14 09:03 PM
maryland
mhead Offline OP
mhead  Offline OP
maryland
ok this is a 2wd drive short bed truck that will be a street strip effort for my now 13 year old. With left over parts that i have it could run high elevens.So im trying to build the drivetrain and get the in and outs of the dakotas.
Re: 91 dakota front hub [Re: mhead] #1654477
08/03/14 09:16 PM
08/03/14 09:16 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I used a 65-67 B body 8-3/4 on my 92 Dakota. Fits perfect with an 8" wide wheel.
Only had to move the spring perches a tad
Re: 91 dakota front hub [Re: hp383] #1654478
08/03/14 09:33 PM
08/03/14 09:33 PM
85086
Lil Herman
Lil Herman
85086
What offset?
Re: 91 dakota front hub [Re: moparpollack] #1654479
08/04/14 12:54 AM
08/04/14 12:54 AM
scratchnfotraction Offline
when looking at the 2000 dak sport my son had, it had the springs on top of axle with the perches at the 43" centers.
same as my 88 d-150 with the A-body 8 3/4 tubbed for 12" rims 4.5 backset. 29x15x15 M/T
I have saw lots of the B-body housings in Daks but running a 8" rim.
I think it would tubb and tuck 12" rims with the A-body 8 3/4 like it does in the 88-440 truck.
94 jeep Cherokee 8 1/4 has 43" perch centers/axle under spring and same width as A-body 8 3/4. we used the perches to line up new weld on perches for axle over spring tubbing/tucking 12" rims in a d-100
if the Dak has the 43" leaf spring centers it should fit A-body 8 3/4 with 12" rims in the fenders same as my 88 d-150
we did a lot of measuring the day we looked at the dak and that's what we came up with. but also figured a 10 rim would be ok as well.
just happed to have a 94-jeep 8 1/4 at the time we pulled measurments and used it in the d-100.
I would be looking at a 8 3/4 going 11s with sticky tires
Re: 91 dakota front hub [Re: scratchnfotraction] #1654480
08/04/14 01:37 PM
08/04/14 01:37 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
even a c-body or truck dana 60 will fit under the dakota--they use a higher offset wheel----i have used an older 9.25 from under a van with the 4.5 pattern...
Re: 91 dakota front hub [Re: scratchnfotraction] #1654481
08/04/14 05:25 PM
08/04/14 05:25 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
The Dak does share the 43" spring center, same as the trucks, and A body.
I'm currently running Cragar Soft 8 wheels, on the '67 B body housing.
http://www.summitracing.com/parts/crr-3975864p/overview/
Picture shows the way it fits with a 295/50/15 on the rear. Front are same wheel in a 7" with a 4.25 backspace.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 91 dakota front hub [Re: hp383] #1654482
08/05/14 12:45 AM
08/05/14 12:45 AM
that B-body and rim package you have is what I see around and very popular.
I cant wait to get a A-body 8 3/4 with 12s tucked with fattys under a Dak
that B-body looks good but fats is where its at
Re: 91 dakota front hub [Re: scratchnfotraction] #1654483
08/06/14 08:24 PM
08/06/14 08:24 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Here is a more better picture of the Dakota. Just got her back from the shop today!
