Housing ends
#165443
12/10/08 02:31 PM
12/10/08 02:31 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Building a Dana for my junk this winter. Ive seen numerous discussions of the different housing ends available, ie mopar ends, big ford ends, etc. Are the mopar ends and bearings sufficient or are the big ford bearings the better deal? If it matters, street car, low 11's for now, but will grow to more. Thanks
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Housing ends
[Re: caper]
#165449
12/10/08 08:40 PM
12/10/08 08:40 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
If you use the big Ford ends you can get the disc brake set up of a ford explorer. Was $385.00 when I bought.
I have that setup
Re: Housing ends
[Re: Quicksilver440]
#165452
12/11/08 12:42 PM
12/11/08 12:42 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
So the late or early Ford endsfor the disks? late?
Re: Housing ends
[Re: Dos Snails]
#165454
01/28/09 06:06 PM
01/28/09 06:06 PM
Late Big Ford for the Explorer disc brakes. I have done the swap twice now. I fyou know your local junkyard guy, you can get teh setup (brackets, calipers, rotors for @ $100) he thing is, you have to remove the axle to get teh caliper bracket off, that is why most junkyards won't do it for you, unless you buy the whole thing. AND to make matters worse, through Ford, the brackets are like $230 EACH! But, again, if you are friendly with local junkyard, look for ANY 96-01 Ford Explorer, and yank the stuff off. Hope that helps.
