Housing ends #165443
12/10/08 02:31 PM
12/10/08 02:31 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Building a Dana for my junk this winter. Ive seen numerous discussions of the different housing ends available, ie mopar ends, big ford ends, etc.
Are the mopar ends and bearings sufficient or are the big ford bearings the better deal? If it matters, street car, low 11's for now, but will grow to more.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Housing ends [Re: Von] #165444
12/10/08 04:51 PM
12/10/08 04:51 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I bought my 8.75 end's thru Jeg's and were made by Strange, I haven't had any durability issues and can use the Mopar brake's, I have never used the Ford end's so I cannot compare them.
Re: Housing ends [Re: Von] #165445
12/10/08 07:42 PM
12/10/08 07:42 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You can use the special big ford type bearings with a special mopar end. There are a number of big sealed bearings avaliable, that are much better then the typical "green" bearing, but cost a bit more. Mark williams seems to me to have widest selection for many applications.
Re: Housing ends [Re: jcc] #165446
12/10/08 08:31 PM
12/10/08 08:31 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
If you use the big Ford ends you can get the disc brake set up of a ford explorer. Was $385.00 when I bought.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Housing ends [Re: jcc] #165447
12/10/08 08:32 PM
12/10/08 08:32 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
What ever ends that you get make sure that they are billet and have enough surface area to compensate for housing misalignment.
I like to use strange or MW ends ,around $100
If you are on a budget 9-plus sells them also they are $30 cheaper I think.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Housing ends [Re: Von] #165448
12/10/08 08:37 PM
12/10/08 08:37 PM
Indiana
65dragnet Offline
Happy Birthday 65dragnet  Offline
Indiana
There is nothing wrong with the mopar ends and bearings that I know of. I had Moser put the Mopar ends on my dana with the Green bearings when I had it narrowed 5 years ago , no issues !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Housing ends [Re: caper] #165449
12/10/08 08:40 PM
12/10/08 08:40 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I have that setup
Re: Housing ends [Re: Defbob] #165450
12/10/08 08:42 PM
12/10/08 08:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
2
Re: Housing ends [Re: Defbob] #165451
12/10/08 09:45 PM
12/10/08 09:45 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Cass..(DR Diff) sells a mopar end that accepts he stock oil seal...most don't from what I hear.
Re: Housing ends [Re: Quicksilver440] #165452
12/11/08 12:42 PM
12/11/08 12:42 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
So the late or early Ford endsfor the disks? late?
Re: Housing ends [Re: Dos Snails] #165453
12/11/08 04:17 PM
12/11/08 04:17 PM
caper Offline
caper  Offline
Give Dr. Diff a call , that is who I got the rear end from with the brakes on it.
Re: Housing ends [Re: Dos Snails] #165454
01/28/09 06:06 PM
01/28/09 06:06 PM
Late Big Ford for the Explorer disc brakes. I have done the swap twice now. I fyou know your local junkyard guy, you can get teh setup (brackets, calipers, rotors for @ $100) he thing is, you have to remove the axle to get teh caliper bracket off, that is why most junkyards won't do it for you, unless you buy the whole thing. AND to make matters worse, through Ford, the brackets are like $230 EACH! But, again, if you are friendly with local junkyard, look for ANY 96-01 Ford Explorer, and yank the stuff off. Hope that helps.
