Rear muffler mounting plates inside trunk--E-BODY #1654361
08/03/14 07:14 AM
08/03/14 07:14 AM
Sweden
71redcuda Online content OP
71redcuda  Online Content OP
Sweden
Hi everyone,
I would like to see if anyone have an original trunk area with the mounting plates in place for the rear muffler brackets.. Im intrested to see what kind of mounting screw there should be for the plates and the finish on them.. I understand the mounting plate itself should be zinc plated.
THANKS
Nicklas
Re: Rear muffler mounting plates inside trunk--E-BODY [Re: 71redcuda] #1654362
08/03/14 02:16 PM
08/03/14 02:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
According to the fastener guide, two different screws have been found in that location. Some were attached through the center hole in the bracket...others were attached through the corner hole.
#10-18 x .50" long pan head Phillips.(zinc)
Optional screw...#10-16 pan head Phillips head with loose captive washer. (Zinc)
Re: Rear muffler mounting plates inside trunk--E-BODY [Re: burdar] #1654363
08/03/14 02:30 PM
08/03/14 02:30 PM
Sweden
Sweden
Understood thanks.
Same as for the washer bottle..
I was thinking that or black zinc on the screws.
