Hole behind timing chain - ?
#1653692
08/01/14 01:12 AM
08/01/14 01:12 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Take a look at the picture. What is the 1/8" hole that is in line with the oil groove behind the cam timing gear? I checked a 440 and 383 block I have and there isn't a hole on them. This is new aftermarket hemi block. I think that is in the casting boss that houses the oil pump drive shaft.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Hole behind timing chain - ?
[Re: Cab_Burge]
#1653694
08/01/14 04:28 PM
08/01/14 04:28 PM
RoadRunner
I was worried is was a pressurized hole. I could see any oil pressure passages near it. But I wanted to make sure I didn't have to drill and tap the hole and add a plug.
