Hole behind timing chain - ? #1653692
08/01/14 01:12 AM
08/01/14 01:12 AM
East Aurora (Buffalo) NY
RoadRunner Offline OP
Take a look at the picture. What is the 1/8" hole that is in line with the oil groove behind the cam timing gear? I checked a 440 and 383 block I have and there isn't a hole on them. This is new aftermarket hemi block. I think that is in the casting boss that houses the oil pump drive shaft.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Hole behind timing chain - ? [Re: RoadRunner] #1653693
08/01/14 03:33 AM
08/01/14 03:33 AM
That is a oil drain back hole, some of the OEM early blocks had them also, most of them didn't
Re: Hole behind timing chain - ? [Re: Cab_Burge] #1653694
08/01/14 04:28 PM
08/01/14 04:28 PM
I was worried is was a pressurized hole. I could see any oil pressure passages near it. But I wanted to make sure I didn't have to drill and tap the hole and add a plug.
2023 Ford Mach 1
