Porting Heads #1653629
07/31/14 09:47 PM
07/31/14 09:47 PM
mn
moparguy93 Offline OP
mn
I am wondering what's the average cost is for getting a set of w2 heads ported. I was at my local machineshop today dropping off a 383bb and he's said for a competition 5 angle valve job was $190 and to port a set of w2 to 310-325cfm would cost me around $500 and $300 for a intake.. is that a good deal?
Re: Porting Heads [Re: moparguy93] #1653630
07/31/14 09:53 PM
07/31/14 09:53 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
That's a very good price. Verify that they have experience hitting those numbers on W2s on a calibrated bench...325 out of W2s require "all out" porting and being iron heads it isn't exactly a quick process if being done by hand.
Request a flow sheet to make sure flow numbers progress at all lifts, max flow isn't important if there is reversion in flow or if the low/mid lift numbers aren't good.
Re: Porting Heads [Re: moparguy93] #1653631
07/31/14 09:55 PM
07/31/14 09:55 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If he is competent.... That is a super deal to port iron heads to that level
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Porting Heads [Re: moparguy93] #1653632
07/31/14 10:28 PM
07/31/14 10:28 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'd be wary.
Sheldon
Re: Porting Heads [Re: moparguy93] #1653633
08/01/14 12:58 AM
08/01/14 12:58 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Where are you in Mn. ?
There is a place in Bloomington called " Headwerx " or something like that.......Earlier this week , I spoke to the guy about getting a set of Eddies done for another deal and he was pretty short with me.
Nice clean shop , but no flow #'s even though he claimed he had done small block MoPar Eddies in the past.
I used Brian at R&R in Spring Lake Park for my W-9's and was very happy with the work and the price.
He is very good........and pretty busy.
Another real Ace and solid MoPar guy is Ron Flood ( Cedar Machine ) and he is up around North Branch.
There are some quality shops in the state and some I wouldn't let work on my lawn mower.
Re: Porting Heads [Re: moparguy93] #1653634
08/01/14 01:10 AM
08/01/14 01:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Unless he has done sets of W-2s theres now way I would
try to get 325 of of them... core shift and he will
be through them... I have 310 out of mine and I did
go through the intake to the push rod.. had to tube
them just the other week because the epoxy let go..
but the price is great
Re: Porting Heads [Re: RUNCHARGER] #1653635
08/01/14 10:22 AM
08/01/14 10:22 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I'd be wary.
Sheldon
X2. Is this guy who can take these heads successfully out to the high end of their potential really going to port iron for $10/hr.? Like some have mentioned, the good shops are BUSY. Is he?
Re: Porting Heads [Re: 67_Satellite] #1653636
08/01/14 02:18 PM
08/01/14 02:18 PM
408Dust Offline
408Dust  Offline
Get what you pay for.
If it sounds to good to be true you know the rest.
Re: Porting Heads [Re: 408Dust] #1653637
08/01/14 03:03 PM
08/01/14 03:03 PM
dogdays Offline
dogdays  Offline
IMHO:
Either he's stupid or he's lying and you don't want either type of person working on your heads.
If the price is a penny less than $1000 something is wrong.
If you want to know more get in touch with Dwayne Porter (or one of the other professionals on the board). He'll give you a straight answer.
R.
Re: Porting Heads [Re: moparguy93] #1653638
08/01/14 03:23 PM
08/01/14 03:23 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
In my opinion with 310-325 being at the extreme end of a w2's capabilities I don't know how someone could even claim that. Most of the casting won't even go there. There would be at least a 50-50 chance in the effort to port that much they would ruin them. The other thought is his numbers are inflated. The bench is calibrated wrong on purpose to get what every one wants.
Re: Porting Heads [Re: littleVAL] #1653639
08/01/14 04:06 PM
08/01/14 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have never heard of 325 out of W-2s.. mine are
actually 308 and that was going through the pinch
but 314 was the most I have heard of on a real bench
that has a good cal.. I flowed mine at work(Chrysler
Cyd head lab) and did everything I could with the
help of the pro there in the lab(old friend of mine)
just to get what I did and still had to tube the intakes..
if that guy can claim a REAL 325... his bench is happy
or he is BSing
Re: Porting Heads [Re: MR_P_BODY] #1653640
08/01/14 04:33 PM
08/01/14 04:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
310 is relatively easy with a W2 head and "the pinch" isn't an issue with that head. Core castings and cracks on some of the econo heads are a problem and knowing what I know now if i used the same casting I would NEVER use the recommended torque values and would do a couple of other things differently. Part numbers get very confusing when dealing with that head. My econo heads both cracked right were the W2 is cast on the header side deck surface. Stock those heads maxed out at 260cfm at between .450-.500 lift and then fell on their face. Bowl and short-turn work easily gets them 300+ even with the 2.02 valve. Then it gets a little trickier and time to upgrade valves.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Porting Heads [Re: MR_P_BODY] #1653641
08/01/14 04:37 PM
08/01/14 04:37 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
The shady dell website shows a flow spec of 324.3 at .650 lift. But I'm pretty sure he's done more than just a few sets of W2s. I dont see anyone spending the required amount of time to reach 325 for $500. Anyone out there have a flow sheet for the CNC ported W2s from Modern Cylinder Head? Seems like I've heard they have a CNC program for them?
Re: Porting Heads [Re: 496 A-body] #1653642
08/01/14 04:45 PM
08/01/14 04:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure than Ryan found a good set to get 324 but
with shift its gonna be a issue... I will take 310
for sure and keep them in one piece... if I want more
I'll get another set of heads and not W-2s
Re: Porting Heads [Re: MR_P_BODY] #1653643
08/01/14 04:54 PM
08/01/14 04:54 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I've got a set of the newest W2s, the guy that I use for porting took a look at them and couldn't believe how much core shift there is.
Re: Porting Heads [Re: 496 A-body] #1653644
08/01/14 05:10 PM
08/01/14 05:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 2 sets.. both econo but one set with long valves
and standard.. the long valve set has a decent amount
of shift the standard is decent... the long valve
set is what I with through
Re: Porting Heads [Re: 496 A-body] #1653645
08/01/14 05:47 PM
08/01/14 05:47 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I have a set that Jeff did several years back. I tried to post the Word doc file, but it doesn't work here. They flowed [Email]321@.650"[/Email] on the intakes, [Email]227.0@.700"[/Email] w/o tube, [Email]264.1@.700"[/Email] with the tube on the exhaust.
Re: Porting Heads [Re: mr_340] #1653646
08/01/14 05:51 PM
08/01/14 05:51 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Exhaust ports.
