almost there E85 #1653458
07/31/14 03:12 AM
07/31/14 03:12 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
finally made the change to E85, got the carb set up from AJ Casini. Will fire it tomorrow and see how it feels. Tired of spending $14 a gallon for VP C12.
Next drop the bullets and put the Dynomax mufflers on so its not too loud on the street
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: almost there E85 [Re: Stroker Scamp] #1653459
07/31/14 12:17 PM
07/31/14 12:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
I think you're really going to like this switch. Should be even faster than on gas as well!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: almost there E85 [Re: Triple Threat] #1653460
07/31/14 02:48 PM
07/31/14 02:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
A.J did mine last year and I love it, car is more consistant and runs much cooler than before, to the point that I have troubles getting enough heat in it,but thats minor compared to the benefits.
Re: almost there E85 [Re: dartman366] #1653461
07/31/14 03:14 PM
07/31/14 03:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If there`s E-85 in Vegas I just may consider the change since I can either do the mods myself or buy the billet blocks and go to town.......
Found several stations in Vegas so what about afr`s.............heard you run it a bit richer than gas.
Re: almost there E85 [Re: Thumperdart] #1653462
07/31/14 03:46 PM
07/31/14 03:46 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
The AFR on mine at WOT is between .77 and .82 lambda (depending on the ethanol content of the fuel). It seems to make good power around there.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: almost there E85 [Re: FlyFish] #1653463
07/31/14 04:13 PM
07/31/14 04:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So lambda is the gauge not afr`s?
Re: almost there E85 [Re: FlyFish] #1653464
08/01/14 04:34 AM
08/01/14 04:34 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I tune mine for between .80 - .85 lambda at the stripe. I have over 600 passes on it, it's never been apart and it still runs like the day I put it in the car.
Re: almost there E85 [Re: Thumperdart] #1653465
08/01/14 04:42 AM
08/01/14 04:42 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dom there is E85 available in Vegas at various local Rebel stations. We have the 65 on E85.
Re: almost there E85 [Re: Thumperdart] #1653466
08/01/14 10:52 AM
08/01/14 10:52 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Lambda just refers to the stoichiometric coefficient for the air/fuel ratio.
1 lambda for gasoline = 14.7 parts air to 1 part fuel.
1 lambda for e85 = mixture is about 9.8 parts air to 1 part fuel.
1 lambda is 1 lambda, so by tuning for lambda you can ignore the actual AFR.
The gauge in your car doesn't know if you are running gasoline or e85, all it can see is the O2 content of the spent exhaust gasses. For example: My AFR gauge (in its regular setup for gasoline) might tell me that I have 12.0 AFR. To get to lambda you just divide your AFR by 14.7, so you get about 0.82 lambda. You could get the real AFR for e85 if you like by converting from lambda (multiply lambda (0.82) by 9.8 = 8.0)….but that would be a pain, and more confusing than helpful. I like to just use lambda for my tuning, and on my gauge I can just flip a switch to make it read out in lambda.
My car is happy between 0.77 and 0.82 lambda. Max power on the rich side for e85 = about 0.72 lambda. Max power on the lean side for e85 = about 0.86 lambda.
I hope that helps more than it confuses.
Re: almost there E85 [Re: dartman366] #1653467
08/01/14 10:58 AM
08/01/14 10:58 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
For that I drilled a hole and tapped it for 3/8 pipe thread and put a ball valve so I can lean it out when I first started to get heat in it and close it when I get to my temp I want which was usually at 175*. I was good for the rest of the day and didn't use to much fuel to warm up.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: almost there E85 [Re: Al_Alguire] #1653468
08/01/14 03:54 PM
08/01/14 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know and am considering the change just not 100% sure on the needed carb mods yet and wonder if my Magnafuel 300 pump will work..........totally new to me.
Re: almost there E85 [Re: FlyFish] #1653469
08/01/14 03:58 PM
08/01/14 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A little confusing but I get lost shaving so,.........So are you saying your wot afr is 12.0? I`d rather stick to afr`s since it took so damn long to get a handle on it...........
