B 400 solid roller #1653234
07/30/14 11:25 PM
07/30/14 11:25 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I would like you opinion on a roller . or what is your set up with a 400 ? I have a 68 RR 3200lb Dana 60 4.88 , 4 link , coil over front . 727 5000 stall ...
Re: B 400 solid roller [Re: robnbird] #1653235
07/31/14 09:46 AM
07/31/14 09:46 AM
gregsdart Offline
gregsdart  Offline
I will just offer some of my results.
499 B motor, 12.9/1 compression, 440-1 heads bowl porting only, Alky injected went 9.34 @ 143 mph with a 283/290/110 UltraDyne cam with about .717 lift. Torqueflite, 3,000 lbs.
4.15 stroke 4.500 bore Megablock motor,440-1 fully ported, alky injected 3,050 lbs went 8.77 at 153 mph with the Isky RR735 cam, 280/288/110 duration, in at 110 using 1.55 rockers for .761 lift.
Comp custom grind put into the 528, 283/296/112, .775 lift in at 110, very little if any gain, no change in power band.
If I were building your motor, it would get all the compression I could build into it for the fuel you plan to use. If your compression comes in at 13/1 or less, I would stick with a cam that is a bit shorter on duration (max intake duration 272 to 280 at .050) but plenty of lift.
Secondly, max port the heads before spending money else where. I have seen 499 motors that went about as fast with ported heads and a solid flat tappet as I have run with a roller and unported heads.
Re: B 400 solid roller [Re: gregsdart] #1653236
07/31/14 11:47 AM
07/31/14 11:47 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
those are some good results Greg and thanks . I was thinking of about 650 lift and about 290ish duration . MP has one that is 300 duration and 625 , and another that is like 297 and 660 . thanks again
Re: B 400 solid roller [Re: robnbird] #1653237
07/31/14 01:07 PM
07/31/14 01:07 PM
SoCal
Brian Hafliger Offline
SoCal
What's been done to the engine itself??
Brian Hafliger
Re: B 400 solid roller [Re: robnbird] #1653238
07/31/14 01:08 PM
07/31/14 01:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I was thinking you were staying at 400 cubes if not heres my Isky solid roller;
.680-.660 lift
.275-280 @ .050
108 lsa installed around 104-105 and 97 degrees overlap
VERY spunky and streetable @ 470 cubes...............
Re: B 400 solid roller [Re: robnbird] #1653239
07/31/14 01:33 PM
07/31/14 01:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
For your goals of 6.0 in the 1/8 499 ci and 3200# thats Way more duration then you Want or need. You could get it done with a roller around 268 to 275 / .650 lift. 290 to 297 In. no need.
Re: B 400 solid roller [Re: Sport440] #1653240
07/31/14 04:34 PM
07/31/14 04:34 PM
gregsdart Offline
gregsdart  Offline
Are we all talking duration at .050 tappet lift?
Re: B 400 solid roller [Re: gregsdart] #1653241
07/31/14 04:40 PM
07/31/14 04:40 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes, That crossed my mine, but that 297/660 lift cam has to be @ .050 The MP 509 advertised is 292/509 The cams hes referring to cant be the advertised duration IMO
Im speaking @ .050 and I know you are too. I hope he knows the difference also. But , looks like he referencing them @ .050 too.
Re: B 400 solid roller [Re: robnbird] #1653242
07/31/14 04:56 PM
07/31/14 04:56 PM
As already mentioned, we need more information on your parts before offering a cam design suggestion Which heads,intake and carb. size, which fuel, intended or desired RPM shift point and so on
Re: B 400 solid roller [Re: robnbird] #1653243
07/31/14 05:20 PM
07/31/14 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cant offer a cam choice without at least head info
such as flow at what lift.. otherwise its a guess..
but the max RPM you want to turn also, fuel
Re: B 400 solid roller [Re: Brian Hafliger] #1653244
07/31/14 06:03 PM
07/31/14 06:03 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I am just now starting on the motor .. I ordered a 4.150 rotating kit with 6.760 rods and 1.120 CH pistons 4.375 bore ... 3200 lb car with 4link , 4.88 coil over front . 727 5000 stall . edelbrock victor max heads .. undecided on a intake and camshaft . So I am all ears
Re: B 400 solid roller [Re: gregsdart] #1653245
07/31/14 06:05 PM
07/31/14 06:05 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
yes at .050
Re: B 400 solid roller [Re: MR_P_BODY] #1653246
07/31/14 06:07 PM
07/31/14 06:07 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Thanks Mr P I just got back and I just posted my info . except the carb and probably a 1050 dom to start with .
Re: B 400 solid roller [Re: robnbird] #1653247
07/31/14 06:09 PM
07/31/14 06:09 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
A DH around 9.970 .. compression close to 12.7 is my calculation
Re: B 400 solid roller [Re: gregsdart] #1653248
07/31/14 06:15 PM
07/31/14 06:15 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Greg thanks .. What would your numbers be for a 650 to a 670 lift .
Re: B 400 solid roller [Re: robnbird] #1653249
07/31/14 06:17 PM
07/31/14 06:17 PM
tboomer Offline
tboomer  Offline
Gonna port those heads?
Re: B 400 solid roller [Re: tboomer] #1653250
07/31/14 06:27 PM
07/31/14 06:27 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
yes I will have them ported but edelbrock doesn't off much of an intake for these heads . I called and they sadi they did not have enough demand .. so I guess a indy 400-3 .
Re: B 400 solid roller [Re: robnbird] #1653251
07/31/14 06:41 PM
07/31/14 06:41 PM
tboomer Offline
tboomer  Offline
My RB has an Indy 440-2. Works pretty good!
Re: B 400 solid roller [Re: robnbird] #1653252
07/31/14 07:40 PM
07/31/14 07:40 PM
gregsdart Offline
gregsdart  Offline
If you are asking what duration for those lift numbers, you can have about any duration you want. Comp cams offers .440 lobes, which have .660 gross lift with 1.5 rockers in durations of from 250 to 290 at .050. They have many other series of lobes, with lobe lifts of .460, .470. .484, etc. A .460 lift cam lobe would be .690, minus lash of say .026, for a net lift of .664
When calculating max lift, you subtract the valve lash from the gross lift. Lets say you have .700 lift, running .026 lash. Net lift will be .674, and actually maybe .010 less due to compression of all the valvetrain parts under load. But lets use a .700 gross lift as a starting point. With a max of .674 net lift, you need to add .070 for a safety margin to spring coil bind. That gives you .744 to add to the spring coil bind height to figure out the shortest possible installed height. If your springs have a coil bind height of 1.130, then add 1.130 to .744 and your shortest installed height is 1.864 There isn't a head made for BB mopars that won't go higher on installed height, so I am not sure why you want to limit the total lift. A gross lift of .700 will actually only reach about .670 as said before, and most heads will keep on flowing above that. Good springs and the right rate of lift on the lobes is as or more important than total valve lift up to a point. .700 to .740 gross lift can be set up to be very reliable and go many rounds without needing maintenance like spring changes and rebuilt lifters.
Re: B 400 solid roller [Re: robnbird] #1653253
07/31/14 07:46 PM
07/31/14 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry I dont see where the head flow stuff is
