Opinions please! #1653025
07/30/14 12:13 PM
07/30/14 12:13 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Have a little over a week till Mopar Nationals and I would like to change the oil in my Super Bee but I only have a little over 4 quarts of Brad Penn oil which I have been using for 3-4 years now. I probably only have about 700 miles on this oil when I changed it in June of last year. So my question is what could I use one quart of to add with the Brad Penn oil? I was thinking of something along the lines of Royal Purple break in oil. So, What would you do if you had this choice? Minus just going out and spending $40.00 - $50.00 on 5 qrts. of the same oil with zinc in it of course! Thanks, Dave!
Re: Opinions please! [Re: superbeedave] #1653026
07/30/14 12:42 PM
07/30/14 12:42 PM
Dave you came to the right place for opinions. Another qt of RP will be fine & no need for the breakin variety but if you have it on hand you will be fine with it
Re: Opinions please! [Re: RapidRobert] #1653027
07/30/14 12:57 PM
07/30/14 12:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks Robert!
Re: Opinions please! [Re: superbeedave] #1653028
07/30/14 01:56 PM
07/30/14 01:56 PM
I would not mix a synthitec oil with a non synthitec oil Isn't all Royal Purple oils synthitec? I like non synthitec Valvoline and if it is a flat tappet motor a bottle of either cam break in additive or Zinc additive
Re: Opinions please! [Re: Cab_Burge] #1653029
07/30/14 05:08 PM
07/30/14 05:08 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this is essentially what I do. name brand oil and a bottle of Lucas break in additive.
Re: Opinions please! [Re: superbeedave] #1653030
07/30/14 09:20 PM
07/30/14 09:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Any motor oil you want
Re: Opinions please! [Re: BSB67] #1653031
07/30/14 09:43 PM
07/30/14 09:43 PM
BDW Offline
BDW  Offline
With only 700 miles why even bother changing it? The time isn't a issue.
Highway miles are the best thing for an engine.
Re: Opinions please! [Re: BDW] #1653032
07/31/14 03:15 AM
07/31/14 03:15 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks guy's for all the advice. Still deciding on what to do. I Will come up with my decision Sat. morning. Leaning towards to not changing the oil till end of year. Thanks again, Dave!
Re: Opinions please! [Re: BDW] #1653033
07/31/14 08:33 AM
07/31/14 08:33 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Best answer.
Re: Opinions please! [Re: superbeedave] #1653034
07/31/14 11:25 AM
07/31/14 11:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unless you think there is water from condensation or fuel in the oil why change it ?
As far as oil to use , Valvoline VR-1 non synthetic is formulated for Flat tappet engine still. you can get it in 10-30 and 10-40
Re: Opinions please! [Re: Cab_Burge] #1653035
07/31/14 02:28 PM
07/31/14 02:28 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Brad Penn is semi-synthetic......not sure how that plays mixing with a synthetic(or non-synthetic for that matter) Either way I agree with the why even change it crowd.
