Re: Opinions please!
[Re: superbeedave]
#1653026
07/30/14 12:42 PM
07/30/14 12:42 PM
RapidRobert
Dave you came to the right place for opinions. Another qt of RP will be fine & no need for the breakin variety but if you have it on hand you will be fine with it
[Re: Cab_Burge]
#1653029
07/30/14 05:08 PM
07/30/14 05:08 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I would not mix a synthitec oil with a non synthitec oil Isn't all Royal Purple oils synthitec? I like non synthitec Valvoline and if it is a flat tappet motor a bottle of either cam break in additive or Zinc additive
this is essentially what I do. name brand oil and a bottle of Lucas break in additive.
[Re: superbeedave]
#1653030
07/30/14 09:20 PM
07/30/14 09:20 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
So my question is what could I use one quart of to add with the Brad Penn oil?
Any motor oil you want
[Re: BDW]
#1653033
07/31/14 08:33 AM
07/31/14 08:33 AM
BSB67
Prospect, PA
With only 700 miles why even bother changing it? The time isn't a issue. Highway miles are the best thing for an engine.
Best answer.
[Re: superbeedave]
#1653034
07/31/14 11:25 AM
07/31/14 11:25 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Have a little over a week till Mopar Nationals and I would like to change the oil in my Super Bee but I only have a little over 4 quarts of Brad Penn oil which I have been using for 3-4 years now. I probably only have about 700 miles on this oil when I changed it in June of last year. So my question is what could I use one quart of to add with the Brad Penn oil? I was thinking of something along the lines of Royal Purple break in oil. So, What would you do if you had this choice? Minus just going out and spending $40.00 - $50.00 on 5 qrts. of the same oil with zinc in it of course! Thanks, Dave!
Unless you think there is water from condensation or fuel in the oil why change it ?
As far as oil to use , Valvoline VR-1 non synthetic is formulated for Flat tappet engine still. you can get it in 10-30 and 10-40
[Re: Cab_Burge]
#1653035
07/31/14 02:28 PM
07/31/14 02:28 PM
Posts: 4,944 WI
Dcuda69
WI
Brad Penn is semi-synthetic......not sure how that plays mixing with a synthetic(or non-synthetic for that matter) Either way I agree with the why even change it crowd.
