Re: Floats for a Carter AVS?
[Re: 62maxwgn]
#165263
12/11/08 01:29 AM
12/11/08 01:29 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
The size of the float makes no difference as long as the level is correct.The difference is in the tang that contacts the needle/seat housing.Bottom is AVS,top two AFB.
I think I have some of those AFB types in my AVS. I can get the right float height numbers, closed and droop.
[Re: Stationwagonguy]
#165265
12/11/08 10:22 AM
12/11/08 10:22 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Oh, and is the Standard part number above definitely the correct one?
If the info is coming from Bill at A&M you can be sure its right.
[Re: 69Cuda340S]
#165266
12/11/08 02:05 PM
12/11/08 02:05 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
That carb you have is in the 600cfm range. The 300 would have had a HP 440 carb in the 725-750cfm range. It will run good and be pretty spunky on the lower end. Upper range? It may fall on it's face. Are you racing, or just cruising? It should MPG a little better than the bigger one.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
#165268
12/11/08 02:35 PM
12/11/08 02:35 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I'm sure it can't do 110 MPH thanks to it's aerodynamics, but it's a lot of fun up top.
/quote]
You just may be surprised!
#165269
12/11/08 02:39 PM
12/11/08 02:39 PM
Posts: 21,448 It's a dry heat
gtx6970
It's a dry heat
That # came right out of the standard parts manual if you use crossover book , all bets are off.
[Re: gtx6970]
#165270
12/11/08 03:28 PM
12/11/08 03:28 PM
RapidRobert
With your weight/gearing that size of carb will work fine for you. I just stopped by my parts house & they show in the standard "hygrade" brand a FL98 float for an AFB & 2 floats for AVS's an FL95 and a FL97. After reading prior posts I dont know if his book was a crossover manual or not
[Re: 62maxwgn]
#165271
12/11/08 04:10 PM
12/11/08 04:10 PM
Posts: 803 Zebulon
Stationwagonguy
A Closet Buick Man
A Closet Buick Man
Zebulon
Haha, I know the speedo is off, but I've put is well past the marked 120 on there. Whether I was really going that fast, who knows.
