Re: Stitch welding
[Re: coro500net]
#1652628
07/30/14 12:39 AM
07/30/14 12:39 AM
Posts: 43,219 Bend,OR USA
Cab_Burge
I have a 67 440 in my 65 Coronet that had a crack between the freeze plugs, I had it stitch welded like 5 yrs ago and never had a problem. My ? Is how reliable is this procedure?as I may be selling the car and just want to inform the buyer about it without scaring the person away.
Do you mean you had it stich repair, AKA lock and stitch repairs on cast iron? Or is it welded electrically?If either and it hasn't leak in five years I wouldn't worry much about it leaking, let your conscions (SP?), morals, be your guide
Re: Stitch welding
[Re: jcc]
#1652630
07/30/14 02:33 PM
07/30/14 02:33 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
And you can always take the serious Buyer for a little ride, get it up to temperature, park it and show them it's not leaking. Can even use a mirror if need be. I am really curious why it's not leaking between welds......either that crack doesn't go all the way into the water jacket, or there isn't water in that spot at all: it's solid iron.
Mo' Farts
Moderated by "tbagger".
Re: Stitch welding
[Re: coro500net]
#1652637
07/31/14 01:27 PM
07/31/14 01:27 PM
Posts: 6,003 Salem
Grizzly
Salem
Would anybody buy a car that had this repair done?
Tough one.
A really rare, must-be-saved-at-all-costs engine, I suppose. Welds can be re-done and re-done until it finally holds. Stock hp level makes it passable but it's not a candidate for someone wanting more.
In your case, 400 engines are still out there and can be used to build a pretty mean stroker on a budget. Your car gives someone something to drive for a while.
If the body and interior of your car is in really nice shape, I would buy it: an engine can be had anywhere from a $150.00 318 that runs to a decent, standard $2000.00 big block. Bodywork, there is no such easy way out, we might as well say it starts at $10,000.00 and just goes up from there.......
I always look at a straight, accident-free car. Engines are cheap.
Who knows, maybe one day the "numbers matching" Owner for that 440 will hunt you down and pay big bucks for it!
Mo' Farts
Re: Stitch welding
[Re: cedarmachine]
#1652638
07/31/14 01:50 PM
07/31/14 01:50 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Peened, finished and polished. The whole chamber will be polished once I finish the seat installation and profile cutting.
Nice work
