Floats for a Carter AVS? #165243
12/10/08 02:09 AM
12/10/08 02:09 AM
Zebulon
Stationwagonguy Offline OP
A Closet Buick Man
A Closet Buick Man
Zebulon
Trying to rebuild the AVS from my '70 300, and realized one of the floats is cracked. Pretty badly at that. Anyhow, I was going to buy a new set of Edelbrock ones from Summit Racing, but they list them for AFB AND SVS carbs, as well as Edelbrock ones. I know the AVS and current Edelbrocks are about the same, but I was under the impression the AFBs are different. Can anyone help me? Are these the right floats for my carb?
http://store.summitracing.com/partdetail...mp;autoview=sku
Part number on my carb is MO 6125S. Unfortunately, I don't even have the floats handy to compare them.
If those aren't right, could someone point me in the direction of the correct ones?
Thanks!
[image][/image] Bob SWG '68 Chrysler Town & Country, 'Katy Jo' '70 Chrysler 300 2-door '78 Impala 2-door
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165244
12/10/08 04:46 AM
12/10/08 04:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
FYI You have the wrong carb for a 70 440, a 6125 is for a 1971 383.
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165245
12/10/08 05:08 AM
12/10/08 05:08 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks!
Can't tell in pic. The AVS floats are taller.
You can heat the leaking brass float, stick it in water, and see where the bubbles come from to spot the leak. Then resolder where it's leaking.
Here's the one you need
Re: Floats for a Carter AVS? [Re: autoxcuda] #165246
12/10/08 12:12 PM
12/10/08 12:12 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
One I have is waaaaay beyond repair. I don't need a hot water test to show me a ginormous 3 mm wide, 2 cm long crack.
Do you know where I can find the correct float?
And I figured the carb wouldn't be the original. Is there any reason this won't work properly on a 440 though?
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165247
12/10/08 12:22 PM
12/10/08 12:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I have in the distant past made an AFB float work in an AVS and the pic from the Summit site looks like the old AFB float.
Re: Floats for a Carter AVS? [Re: Jim_Lusk] #165248
12/10/08 01:23 PM
12/10/08 01:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Now that I look through my carbs... I have both short and tall one in there. Just get them to match side to side. Play with the tongs to get the spec'd droop and rise float settings.
Re: Floats for a Carter AVS? [Re: autoxcuda] #165249
12/10/08 01:27 PM
12/10/08 01:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: Floats for a Carter AVS? [Re: autoxcuda] #165250
12/10/08 01:54 PM
12/10/08 01:54 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
See, I wouldn't know how to change the settings on it. Still don't know enough about carbs. ops:
Seriously, is there a part # or something so if I ordered them from someone I'd know I have the right part?
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165251
12/10/08 02:08 PM
12/10/08 02:08 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
I just talked to a guy at a carb shop that told me that I cannot use a AFB float, or a newer Carterbrock float, and that there were 4 different original AVS floats from his memory, but wouldn't tell me which one I needed unless I bought a $200 rebuild kit from him that included them.
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165252
12/10/08 02:16 PM
12/10/08 02:16 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
Poking around, I *think* this is the correct one for me, Carter float #F34. Anybody know?
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165253
12/10/08 02:28 PM
12/10/08 02:28 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a holley rebuilt 6125 at home. Runs fine. I'll check the float in it. I'm pretty sure its that Napa 2-426.
Std rebuilt AVS kit w/o floats is like $40-$50.
Some carb guys are p@#$ks. One in MO once wouldn't sell me anything until I gave him some statement that carb was for off road application or some stupid stuff. Another rebuilt a holley for me and when I asked for the old parts, they tore the gaskets, like it was illigal to reuse them.
If you don't know how to adjust float, this question seems moot.
I think if you asked here in Q and A you could learn, IF you are willing??
Do you have a 69-71 Factory manual? Someone here may be able to send you a scan of the carb section.
Re: Floats for a Carter AVS? [Re: autoxcuda] #165254
12/10/08 02:32 PM
12/10/08 02:32 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
I wasn't really aware that floats could be adjusted. All I know is the ones I have are cracked and need to be replaced. :shrug:
I would like to learn, yes. I guess I have a lot to do though, haha...
Yeah, I've realized quite a few carb people are nuts. I've been having some weird conversations trying to figure this out.
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165255
12/10/08 02:32 PM
12/10/08 02:32 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
And I have a '70 manual, but if this is a '71 carb, would it help? I guess I gotta peek through it...
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165256
12/10/08 03:01 PM
12/10/08 03:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
float # FL97 Standard
List price is just under $18
Re: Floats for a Carter AVS? [Re: gtx6970] #165257
12/10/08 03:27 PM
12/10/08 03:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The size of the float makes no difference as long as the level is correct.The difference is in the tang that contacts the needle/seat housing.Bottom is AVS,top two AFB.
Re: Floats for a Carter AVS? [Re: 62maxwgn] #165258
12/10/08 04:19 PM
12/10/08 04:19 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
What sort of measurements are there to make sure it's in spec? I'm confused, you just bend the tabs until it sits where you want it to then? What does this effect?
I really do appreciate the info, I'm not from a family of car people, so I've never had anyone to really teach me any of this sort of stuff.
Thanks.
Oh, and is the Standard part number above definitely the correct one?
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165259
12/10/08 04:43 PM
12/10/08 04:43 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
You are not yet ready to walk on the ricepaper grasshopper. Seek the wisdom of carb book and learn the ways of venturi and float....
Re: Floats for a Carter AVS? [Re: dmerc] #165260
12/10/08 05:08 PM
12/10/08 05:08 PM
With the float level setting where you want it you want the tang to be contacting the needle at pretty close to a 90 degree angle.
Re: Floats for a Carter AVS? [Re: RapidRobert] #165261
12/10/08 06:51 PM
12/10/08 06:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There are two settings:
Float level
Float drop
If you go through your manual you will get an idea of how they are set. Float level is set first with the carb air horn upsidedown. This is the level that will close off the incoming fuel. Float drop is the distance the float will drop to open the needle valve to let fuel in.
Re: Floats for a Carter AVS? [Re: Jim_Lusk] #165262
12/10/08 08:45 PM
12/10/08 08:45 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
Float level
Float drop
As usual, Jim saves the day.
Thanks for the info, I'm gonna go read through the manual a bit.
I did try a whole bunch of local parts stores. No one can find floats for me. One could find them and can't order them, another pulled out a carb book, and under the part # on my carb, there is no float part # listed at all. Float part numbers listed for everything else BUT mine. Typical.
Any other suggestions? I got a few numbers to some local private folks who might, but I thought I'd ask again here.
