what oil is everyone using #1650816
07/25/14 01:17 PM
07/25/14 01:17 PM
kentucky
b body idiot Offline OP
kentucky
I have been using Rotella but looking at maybe changing to a synthetic what are some recommended
brands with or without an additive.
Thanks,
Mike
Re: what oil is everyone using [Re: b body idiot] #1650817
07/25/14 01:38 PM
07/25/14 01:38 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
amsoil,and mobil 1 my opinion amsoil is better dipstick is so slippery
Re: what oil is everyone using [Re: b body idiot] #1650818
07/25/14 01:49 PM
07/25/14 01:49 PM
scratchnfotraction Offline
Royal Purple 10-30 Mopar filter/Napa gold filter
got a 5 quart jug Royal Purple and a Mopar filter for 48$ at Wal-Mart.
Re: what oil is everyone using [Re: d-150] #1650819
07/25/14 01:49 PM
07/25/14 01:49 PM
Andrewh Offline
Andrewh  Offline
+1
for my dd it is amsoil, for the old car and wifes mobil 1.
if mobil 1 made it for my dd I would probably use that too, but that is only because amsoil was a bit more.
Re: what oil is everyone using [Re: Andrewh] #1650820
07/25/14 01:58 PM
07/25/14 01:58 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
VR1 ...easy to find cheap and works great!
Re: what oil is everyone using [Re: b body idiot] #1650821
07/25/14 02:07 PM
07/25/14 02:07 PM
Georgia
Steve Bryant Offline
Georgia
My local engine expert told me to keep using Rotella T 15W40 or Valvoline VR1 40 in my 440.
Whenever it goes on sale at O'Reilys I pick some up and that helps to keep the costs down.
Re: what oil is everyone using [Re: scratchnfotraction] #1650822
07/25/14 02:08 PM
07/25/14 02:08 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I run Brad Penn for engine break in, same for when breaking in a new cam. Valvoline VR1 for regular use. Mopar filters, WIX or Napa Gold series. Sometimes I use a FRAM HP1.
The daily rig is a 2007 Ram. I run whatever 5w20 is on sale but always a name brand oil along with a WIX or Napa filter.
Re: what oil is everyone using [Re: b body idiot] #1650823
07/25/14 02:08 PM
07/25/14 02:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Royal Purple oil and filters
Re: what oil is everyone using [Re: scratchnfotraction] #1650824
07/25/14 02:10 PM
07/25/14 02:10 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Why do you consider yourself and idiot?
Re: what oil is everyone using [Re: Kern Dog] #1650825
07/25/14 02:47 PM
07/25/14 02:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Kendall GT1 in the 440 and 413 plus the Harleys.Ive used it since the 70s and never a problem.I do buy Valvoline race oil when its cheap.Bought 2 cases a few years ago.Buy one case get one case free.Rocky
Chrysler Firepower
Re: what oil is everyone using [Re: therocks] #1650826
07/25/14 03:07 PM
07/25/14 03:07 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Brad Penn
Break-in for a new build then change to the 10w40 or 20w50 depending on which motor I have it in.
Pennzoil 20w50 racing prior to using Brad Penn.
...FAFO...
Re: what oil is everyone using [Re: b body idiot] #1650827
07/25/14 11:10 PM
07/25/14 11:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like and use straight non synthetic Valvoline 5W20WT in all my cars My 2006 Ram 3500 CTD gets either Rotella or Delo 400 15w40WT , diesel oil in the diesel motors I have used some of the new Pennzoil 25W50 WT in several high output race motors, it is very slippery when rubbed between the fingers and thumb I keep in mind that oil does two things in motors, it cools and lubricates If my motors don't show any sign of lubricant failures on inspections I stick with what works Synthetic oils have come a long way in the last 15 yrs, maybe some day I will try them again on some of my own stuff The last synthetic oils I used was in my airplane, Mobil AV 1, it made that motor sludge up in less than 400 hrs of use It was removed from the market after a massive class action lawsuit settlement , I didn't get in on that I've heard conflicting reports on diesel oil frothing in gas motors at the upper RPM, above 3000 RPM
Re: what oil is everyone using [Re: Cab_Burge] #1650828
07/26/14 12:10 AM
07/26/14 12:10 AM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
VR1 with Napa Gold filter
B5 Challenger T/A
Re: what oil is everyone using [Re: KARLN] #1650829
07/26/14 12:14 AM
07/26/14 12:14 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Depends on what cam is in the engine. Flat tappet cam engines need Rotella T or some other diesel oil w the zinc addives...Roller cam engines can use any modern oil....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: what oil is everyone using [Re: KARLN] #1650830
07/26/14 12:18 AM
07/26/14 12:18 AM
IN
ahy Offline
ahy  Offline
IN
Rotella T 15W40 in the '70E BB. Rotella synthetic 5w40 in the '98 DOHC Neon. Slipper follower cams (Neon) like zinc also. This example needs to start in really cold weather. Over 150k on the Neon and runs great/uses little oil.
Re: what oil is everyone using [Re: HemiRick] #1650831
07/26/14 12:31 AM
07/26/14 12:31 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
I have used Pennzoil non synthetic for more than 30 years.I don't think that synthetic is worth the money. 6 years ago a friend bought a new Ram 4x4 and from day one he only used high test gas and synthetic oil. With less than 100K miles he lost oil pressure.He pulled the oil pan and the sludge was almost thick as peanut butter and 2 inches deep,never had that problem with Pennzoil.
Re: what oil is everyone using [Re: Kern Dog] #1650832
07/26/14 12:33 AM
07/26/14 12:33 AM
Re: what oil is everyone using [Re: scratchnfotraction] #1650833
07/26/14 02:07 AM
07/26/14 02:07 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I run whatever is on sale! I'm a bit more selective on filters, but not much. Everything I own has over 100K miles, the vehicles will fall apart long before any motor oil problems will take them out.
When I was young, I cared more about things like oil, but now that I've become older, I sound like my dad. The only motor failures I've ever had that could have been a result of an oil problem, also had high rpm conditions. The high rpm was always present with the motor failures. Hard to blame the oil when the tach read 7,000+ on a basically stock motor. Gene
Re: what oil is everyone using [Re: poorboy] #1650834
07/26/14 03:32 AM
07/26/14 03:32 AM
SE PA
Yellow Fever Offline
SE PA
Old cars, rotella and ZDDP plus.
New cars, whatever is on sale with wix filters. I change it too often so I am going back to dino oil, not worth synthetic.
Re: what oil is everyone using [Re: Kern Dog] #1650835
07/26/14 03:48 AM
07/26/14 03:48 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Why do you consider yourself an idiot?
By the way, THE ABOVE was in reference to the OPs screen name. I was making a silly joke. It was N O T meant to insult anyone here. Sorry for any confusion.
