can this head be repaired?
#1650748
07/25/14 03:55 AM
07/25/14 03:55 AM
Posts: 4,179 California
mickm
California
the crack is obvious. what do you think? i'm no expert by any means, but this doesn't seem to be in a high stress area. welded up and ground down, should be good to go.
yes? no? maybe??
Re: can this head be repaired?
[Re: sasquatch]
#1650752
07/25/14 12:30 PM
07/25/14 12:30 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Short answer Yes it can be repaired. However you cannot simply weld it up and grind it down. You have to grind out the crack to its ends in both directions. It will probably end up looking like it was hit with an artillery shell when you are done and then you start welding. The head needs to be heated up (alot) while you are welding. This is not cheap or easy. I can see that someone spent a fair amount of time in the ports so getting anther head to match will also entail a good bit of work. Tough call....Todd
Im with Todd on this one. Looks like some work was done and also if I am seeing correctly,milled down or Max Wedge style rocker pads, so that means probably a head you want to keep, or at least not replicate? It can be repaired, and will cost a few bucks, with of course, no guarantee how long it may last. Just comes down to financial judgement, and roll of the dice, knowing how much it may or may not be used.... ![](/ubbthreads/images/graemlins/shruggy.gif)
RIP Monte Smith
[Re: CompWedgeEngines]
#1650753
07/25/14 12:49 PM
07/25/14 12:49 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We did lots of cast iron welding in the mill because we had to as a lot of our rolling mill parts were over 50 years old. Our best (longest lasting) repairs were ones we could drill both ends of the crack to keep it from going any further, grinding out the crack, heating the part, welding the part with a high nickle rod, and then slowly cooling the part. We would then peen the repair with a hammer and then grind as needed. There are some REAL GOOD rods available to do repairs like this. I have also tig welded cracks with stainless filler on heads and between cylinder bores on blocks with some success but that takes more time (and grinding). It probably won't be cheap to have repaired so make sure its worth while before searching for a shop that will take on the project.
