4-speed guys, did you hook up a switch to your pedal?
#1650737
07/25/14 01:36 AM
07/25/14 01:36 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Trying to help a guy with a 4-speed car and wondering if you guys that race 4-speeds hook up a switch to your clutch pedal to activate the line lock and 2-step?
I'm thinking this would be how you staged and launched consistently???
Roll in, turn on the top bulb, creep in until you turn on the 2nd bulb, depress the clutch all the way to trigger the switch to activate the 2-step and line lock (mash the go pedal) and then when the 3rd yellow flashes, you side step the clutch with releases the line lock and motor goes wide open throttle and you get a view of the clouds...
I would also have a manual switch to activate the line lock for the burn out (may hook the hot directly and let either of the switched provide ground)
Or am I completely off track, if so let me know how you guys make it work? (keeping consistency in mind)
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: 4-speed guys, did you hook up a switch to your pedal?
[Re: WadeMetzinger]
#1650738
07/25/14 01:41 AM
07/25/14 01:41 AM
Posts: 999 British Columbia
toddd
British Columbia
I have a "trans brake" style button on my steering wheel for the line lock, and a switch on my pedal stop for my 2 step.
[Re: WadeMetzinger]
#1650739
07/25/14 01:44 AM
07/25/14 01:44 AM
Posts: 1,169 MI
68shifter
MI
Some use a switch off the clutch, some will put a micro on the shift lever so when your in first it's engaged. Either works. I for a while just used used the line lock button on the shifter but the problem with that was I'd inadvertently hit it while shifting and pretty much turns on a rev limiter for whatever pill you have in your two step. Here's a common clutch switch. http://www.jerrybickel.com/electrical-components/clutch-operated-switch-jbrc5509.html
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: WadeMetzinger]
#1650742
07/25/14 11:39 AM
07/25/14 11:39 AM
Posts: 10,022 MN
JERICOGTX
MN
I have a switch on my pedal and shifter. The 2 step has to have BOTH pressed in for it to work. This way it does not get activated in the burnout box, or when changing gears.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1650744
07/25/14 01:18 PM
07/25/14 01:18 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I have the 2 step wired thru a relay. The control circuit of the relay is a "latching relay" that is triggered by a momentary switch on the dash and released by a switch when the clutch pedal is released. The switch on the pedal does not release the 2 step until the pedal is all the way up. So when I am pre-staged, I hit the momentary switch to activate the 2 step. Then I can creep ahead to stage, without fully releasing the clutch pedal, so the pedal switch is not activated so the 2 step is still in play. When I dump the clutch to launch, the pedal hits the switch and the latching relay is released, cancelling the 2 step until the momentary switch is pressed again while I am pre-staged on the next pass. I like it because I don't have to think about it at launch, I don't have to involve my hand in the launch. Other than arming while pre-staged, it is all automatic. A latching relay is no different than any other relay, it is only wired different. the hot goes to a normally closed switch on the clutch pedal, that is opened when the pedal is fully released.
[Re: SLOW67]
#1650746
07/27/14 02:50 PM
07/27/14 02:50 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I used a Radio Shack micro switch with a roller that contacts the clutch pedal near the pivot. Very little movement required and reacts fast. I used the MSD wiring schematic. Arm it with the clutch pedal down, release the shifter button. On launch, clutch releases the 2-step and the Line Lock at the same time.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 6pak2go]
#1650747
07/27/14 02:52 PM
07/27/14 02:52 PM
6pak2go
Mesa, Arizona
Here's the switch installed. The other side of the switch is used as a starting safety switch.
