Re: Pro-Systems 4150 carbs
[Re: SKR8PN]
#165063
12/09/08 09:35 PM
12/09/08 09:35 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
When it comes to custom carbs,there are alot of good people and good products.I have used Patrick also on a big motor carb,and it worked great and he has great customer service..
But,if you want a double throw down carb call Steve at PRC or Dale Cubic at CFM...I have used PRC the last few years and it is the best carb I have ever had.Dale at CFM is building me a big bore carb right now...
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: Darryls-Demon]
#165066
12/10/08 01:51 AM
12/10/08 01:51 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I have used a few of Patricks carbs. His customer service is second to none. All the carbs I have used form him were very good performers. I am currently running a Gary Williams Dominator.
[Re: BradH]
#165068
12/10/08 09:10 PM
12/10/08 09:10 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
Sounds like Patrick James has quite a following. It would have been nice to hear some real "before" and "after" data, though.
In the mean time, I'm going to try and tune a little more streetability into my current carb... maybe even pick up a wide-band sensor setup. What's on the car now runs hard and consistent at the track, but could drive a bit cleaner down low.
Im gonna try and get some real world comparisons. I bought a Pro Systems 1000 cfm 4150 carb from him and I also have a Demon 1000 cfm drag race series carb that was on the car before hand. I'm gonna go to the track with both carbs and try them both on the same day and see if there is any difference. Im gonna bring my jet kit with me and make sure they are both jetted correctly. So far is seems to run great, but I dont know if it actually is any faster or not. Ill post the results when I get to try them both out.
[Re: SKR8PN]
#165070
12/11/08 11:06 AM
12/11/08 11:06 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Brad, if you want to try mine out (1000hp), let me know.
440Jim tried it on his Dart back when he had the 470 and he picked up close to a 10th on a (at the time) high 9/low 10 car, wish he took more time to tune with it, I think (IIRC based on his incrementals) there was potentially more in it.
Patrick is top notch!
