Minimum clearance needed for Phoenix FX 10.5-29.5 slick #1650723
07/25/14 12:29 AM
07/25/14 12:29 AM
VT
MOPARCRAZY Offline OP
VT
I had Hoosier 30x 10.5 radials and am trying to switch to Phoenix bias tires. How much diameter do the 29.5 bias tires grow during the run? I think I need to cut my opening but am wondering how much clearance is minimum? Any help appreciated.
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: MOPARCRAZY] #1650724
07/25/14 01:04 AM
07/25/14 01:04 AM
!/8 mile or 1/4 mile and MPH?
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: Cab_Burge] #1650725
07/25/14 01:12 AM
07/25/14 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Plus whats the rear weight
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: MR_P_BODY] #1650726
07/25/14 10:28 AM
07/25/14 10:28 AM
VT
VT
currently 1/8 mile at 108 mph
rear weight I don't recall but can look it up, 69 dart full interior so its heavy, car weight 3200
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: MOPARCRAZY] #1650727
07/25/14 10:44 AM
07/25/14 10:44 AM
gregsdart Offline
gregsdart  Offline
One inch at the center, a little less on the edges. You may get by with 3/4 inch, but it would be VERY close.
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: MOPARCRAZY] #1650728
07/25/14 05:15 PM
07/25/14 05:15 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We had that tyre after running M/T's and Hoosiers of the same designation. Great tyre, but it rubbed at the bottom front of the arch.
Actual diameter was over 30.5 inches, we had to change back to M/T's. We had around an inch clearance too.
Re: Minimum clearance needed for Phoenix FX 10.5-29.5 slick [Re: Tig] #1650729
07/28/14 11:30 PM
07/28/14 11:30 PM
VT
VT
Thanks for the input. Looking to be ready for the NATS, I think my best option may be to cut my losses and sell these and buy MT's which are smaller, otherwise I have some cutting to do.
