572 twin turbo build? #1650196
07/23/14 10:38 PM
07/23/14 10:38 PM
griff70440 Offline OP
hello ,
I`m picking up my first 572 cubic inch motor at the nats this year.
Its a used motor. I`m going to take it to my motor guy and go through it. the plan is to add some turbos to it. LOL
Is anyone running this type of set up?
if so what are your motor specs? compression ,cam , ect...
is it true that for every 15 psi of boost your compression go's up 1
point?
thanks,
Mike
Re: 572 twin turbo build? [Re: griff70440] #1650197
07/24/14 01:31 PM
07/24/14 01:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
No.
Boffin Emeritus
Re: 572 twin turbo build? [Re: griff70440] #1650198
07/24/14 01:39 PM
07/24/14 01:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
hello ,
point?
thanks,
Mike
Why turbo such a big motor? That makes no sense to me.
Re: 572 twin turbo build? [Re: griff70440] #1650199
07/24/14 01:49 PM
07/24/14 01:49 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Based on your questions, and not to be mean, but you need to do a lot of research and get educated on turbo setups.
First and most importantly, what are your goals? Once we know that, we can suggest, cubic inch, heads, cam, compression, internal engine parts, turbo sizing, etc.
Re: 572 twin turbo build? [Re: TheOtherDodge] #1650200
07/24/14 04:33 PM
07/24/14 04:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Kind of.
Re: 572 twin turbo build? [Re: griff70440] #1650201
07/24/14 04:56 PM
07/24/14 04:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
hello ,
point?
thanks,
Mike
A twin turbo intercooled 572 C.I. pump gas wedge motor can make north of 2000 HP+ How much HP can your car handle I hope your new used motor is in good shape, maybe needing a freshen only How fast(actually) have you been in a car Be careful, first and formost
Re: 572 twin turbo build? [Re: griff70440] #1650202
07/24/14 05:38 PM
07/24/14 05:38 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Forget the turbos with that motor and 2900# Duster.
10.5 comp. and the MP 590 cam will get you your easy 9 sec. street ride.
Unless your goals have changed and you want 8,s with it now.
Like others have asked, how fast have you been. Id start with the 572 first and then decide whether or not you want to Bother with Turbos.
No reason to Twin Turbo a 572 with a 2900# car unless you want to run7,s or something.
Re: 572 twin turbo build? [Re: Sport440] #1650203
07/24/14 10:00 PM
07/24/14 10:00 PM
thanks for the replies. LOL
I plan to have the motor freshened. I got a great deal on the motor thats why I am buying it. as for the turbos it was just a Idea. I have a line on two 88 mm turbos.
the duster should handle mid 8`s no problem.
Re: 572 twin turbo build? [Re: griff70440] #1650204
07/25/14 12:50 PM
07/25/14 12:50 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If you are getting a good deal on the engine & turbo's then by all means build it.With the twin turbos I would run a tunnel ram,do it while you have the chance because you may never find another good deal to do it in the future.
You can start off running it mild & as you upgrade your car you can keep adding Boost to it.
PS if nothing else do it for the WOW factor!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 572 twin turbo build? [Re: Challenger 1] #1650205
07/25/14 12:55 PM
07/25/14 12:55 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Locally , there is a twin turbo 69 Dart ragtop for sale , with a nice Indy headed big block
22,500 turn key
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 572 twin turbo build? [Re: bigdad] #1650206
07/25/14 08:05 PM
07/25/14 08:05 PM
Houston, Texas
Houston, Texas
Well I guess he got the information he was looking for... Looking forward to seeing the progress on this!
Re: 572 twin turbo build? [Re: TheOtherDodge] #1650207
07/25/14 08:18 PM
07/25/14 08:18 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Been running a turbo'd 572 for years in my street car. Don't need much boost to go fast and you don't wreck parts since your not running on the ragged edge.
What heads/compression etc does this 572 have?
I can give you some direction if your thinking of doing it. 7's aren't too hard to get at 3500lbs on pump gas.
Switching to bigger heads and twins now but you can do some amazing things on nothing special for parts.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: 572 twin turbo build? [Re: Efidart] #1650208
07/27/14 12:41 PM
07/27/14 12:41 PM
thanks guys. I will keep you posted.
The heads are 572-13 and the compression 14-1
I`m thinking I`ll have to lower the compression
to 11-1 or 12-1.
What do you guys think?
Re: 572 twin turbo build? [Re: griff70440] #1650209
07/27/14 02:10 PM
07/27/14 02:10 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
to 11-1 or 12-1.
your going to need a swimming pool shaped piston to get the right compression with those heads and that stroke
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 572 twin turbo build? [Re: bigtimeauto] #1650210
07/27/14 05:32 PM
07/27/14 05:32 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
yeah...about the size of your combustion chamber!
Re: 572 twin turbo build? [Re: griff70440] #1650211
07/27/14 06:24 PM
07/27/14 06:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
to 11-1 or 12-1.
Much lower then that, for what your trying to do. More like 8.5 to 9.5 max.
Re: 572 twin turbo build? [Re: Sport440] #1650212
07/27/14 09:43 PM
07/27/14 09:43 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
On my Super-Charged engine(which makes over a 1,000 Streetable RWH) my CR is 10.7-1 and I'm almost positive on the Turbo engines they stay at 10.7-1 also.I would talk with what they now call Tuners that work on the Super-Charged & Turbo engines.The Turbo & Super-Charged engines have come a long way in the last few years.
Re: 572 twin turbo build? [Re: MRMOPAR622] #1650213
07/28/14 05:36 PM
07/28/14 05:36 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Mid high 9's for comp if your sticking to a pump gas type engine and 50+cc dish, 9.7:1 here.
Made 1550RWHP on 17 LBS with edelbrock Victor 440's. Since you have bigger heads you could be 1500rwhp on 13-14 lbs on pump gas with A/W intercooler.
Re: 572 twin turbo build? [Re: MRMOPAR622] #1650214
07/28/14 05:45 PM
07/28/14 05:45 PM
Houston, Texas
Houston, Texas
I can safely comment that turbo apps making 1,000 rwhp on pump 91-93 gas are not using 10.7:1 compression ratio unless they are adding meth or something like that.
Re: 572 twin turbo build? [Re: TheOtherDodge] #1650215
07/28/14 07:06 PM
07/28/14 07:06 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Also, the OP, must decide what fuel he will want to run, to finalize compression, or be prepared to adjust things otherwise, like stated above.
