Re: how fast with steel head 440 and hydraulic cam
[Re: cudadoug]
#1650075
07/23/14 05:40 PM
07/23/14 05:40 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
440 906 head victor intake 10.88 121mph 727 4500 stall 4.30 outback 28.5 10.5 m/t 3300lb 67 gtx @ 2000 feet air..... 6000rpm
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: dogdays]
#1650077
07/23/14 09:15 PM
07/23/14 09:15 PM
Posts: 97 Florida
johnmilner
10.58 @126 3800# 200 shot nos. 430 gear m-1 intake 830 cfm
[Re: dogdays]
#1650078
07/23/14 09:16 PM
07/23/14 09:16 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I'm thinking a rail dragster could get into single digits pretty easily.
R.
I bet there are plenty of door cars that have done it too.
[Re: mcat4321]
#1650080
07/23/14 10:59 PM
07/23/14 10:59 PM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
440-C iron Indy heads, bowl porting, 475 cubes, 12.5 1 compression, 750 Holley methanol carb, torqueflite, 4.56 gears, 14x32 slicks, 3180 weight, .540 lift 268 @ .050 cam, 10.10 at 132 mph.
[Re: mcat4321]
#1650081
07/24/14 03:31 PM
07/24/14 03:31 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I ran a best of 11.86 (real good air) with a 320 .533 lift mopar purple shaft HYD in a 3800 lb car with ported 906 was a real solid 12.0 to 12.1 car. Lash set so it lightly ticked setting adjustable pushrods is a PITA. Not sure if it was the heads or cam but liked 5800 to 6200 shifts best higher and it slowed down. 4.1 gear teamG intake 800 holley
[Re: TheOtherDodge]
#1650084
07/24/14 10:29 PM
07/24/14 10:29 PM
Posts: 236 upstate, New York
jvcuda
upstate, New York
'73 cuda, 3600 lbs. torker intake, old! 750 holley carb 346 stock heads, mild isky cam 3.91 gears, 295/55/15 MT street radials 440 bored .055 over, 4.125 stroker crank power steering,brakes hedman headers 1 3/4 primary tubes
1.615 60ft 7.444 1/8 11.76 1/4 112.64 shifting at 5500
calt 2335, bar 29.74, hum 43%
[Re: Dodgem]
#1650087
07/30/14 11:39 AM
07/30/14 11:39 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
11.40 at 117.4 mph. 440 w/ 915s, 509/292 purpleshaft, Edelbrock performer rpm intake, 4.10 gear, 28x10.5, 3700 lbs. through the mufflers.
[Re: mopar dave]
#1650089
07/30/14 09:03 PM
07/30/14 09:03 PM
Posts: 182 USA
Nitrofish
USA
69 B-Body 440 with 906 heads 6-pack 509 purple shaft 727 3500 10" Turbo Action 4.10 with slicks 11.66 ET at 119mph.... Forget the exact MPH but he ET is accurate Have FUN!!
