how fast with cast iron head 440 and hydraulic cam #1650071
07/23/14 02:51 PM
07/23/14 02:51 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
And what did you weigh
what gear
what intake
Re: how fast with steel head 440 and hydraulic cam [Re: mcat4321] #1650072
07/23/14 04:45 PM
07/23/14 04:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
10.81 3.91 gear RPM intake, 3100#
Re: how fast with steel head 440 and hydraulic cam [Re: Sport440] #1650073
07/23/14 05:31 PM
07/23/14 05:31 PM
dogdays Offline
dogdays  Offline
Ferrous Mopar cylinder heads are cast iron, not steel.
R.
Re: how fast with steel head 440 and hydraulic cam [Re: Sport440] #1650074
07/23/14 05:33 PM
07/23/14 05:33 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
11.41 @ 117
3340 #
3.91 gear
Edelbrock Torker. (The original version)
Re: how fast with steel head 440 and hydraulic cam [Re: cudadoug] #1650075
07/23/14 05:40 PM
07/23/14 05:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
440 906 head victor intake 10.88 121mph 727 4500 stall 4.30 outback 28.5 10.5 m/t 3300lb 67 gtx @ 2000 feet air..... 6000rpm
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: how fast with steel head 440 and hydraulic cam [Re: WHITEDART] #1650076
07/23/14 08:37 PM
07/23/14 08:37 PM
dogdays Offline
dogdays  Offline
I'm thinking a rail dragster could get into single digits pretty easily.
R.
Re: how fast with steel head 440 and hydraulic cam [Re: dogdays] #1650077
07/23/14 09:15 PM
07/23/14 09:15 PM
johnmilner Offline
johnmilner  Offline
10.58 @126
3800#
200 shot nos.
430 gear
m-1 intake
830 cfm
Re: how fast with steel head 440 and hydraulic cam [Re: dogdays] #1650078
07/23/14 09:16 PM
07/23/14 09:16 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
R.
I bet there are plenty of door cars that have done it too.
Re: how fast with steel head 440 and hydraulic cam [Re: Sport440] #1650079
07/23/14 10:58 PM
07/23/14 10:58 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I ran a 12.3 @ 109 with stock 2.08/1.74 906's on a basic rebuilt bottom end with a MP .484. 3.73 gear in a 3300lb 73 Duster.
Re: how fast with steel head 440 and hydraulic cam [Re: mcat4321] #1650080
07/23/14 10:59 PM
07/23/14 10:59 PM
gregsdart Offline
gregsdart  Offline
440-C iron Indy heads, bowl porting, 475 cubes, 12.5 1 compression, 750 Holley methanol carb, torqueflite, 4.56 gears, 14x32 slicks, 3180 weight, .540 lift 268 @ .050 cam, 10.10 at 132 mph.
Re: how fast with steel head 440 and hydraulic cam [Re: mcat4321] #1650081
07/24/14 03:31 PM
07/24/14 03:31 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I ran a best of 11.86 (real good air) with a 320 .533 lift mopar purple shaft HYD in a 3800 lb car with ported 906 was a real solid 12.0 to 12.1 car. Lash set so it lightly ticked setting adjustable pushrods is a PITA. Not sure if it was the heads or cam but liked 5800 to 6200 shifts best higher and it slowed down.
4.1 gear teamG intake 800 holley
Re: how fast with steel head 440 and hydraulic cam [Re: Dodgem] #1650082
07/24/14 05:22 PM
07/24/14 05:22 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
11.13 with 3700# Challenger 496" Eddy RPM heads, XE295HL cam, 4.30 gear, 4200 stall shifting at 6000 and 6 pak carburetion.
Have now gone to an XTQ294 solid and has run 6.75 in the 1/8th ( about 10.60 or so in the 1/4).
Re: how fast with steel head 440 and hydraulic cam [Re: superwrench] #1650083
07/24/14 06:57 PM
07/24/14 06:57 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Some interesting 440 motors with steel heads..
Re: how fast with steel head 440 and hydraulic cam [Re: TheOtherDodge] #1650084
07/24/14 10:29 PM
07/24/14 10:29 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
'73 cuda, 3600 lbs.
torker intake, old! 750 holley carb
346 stock heads, mild isky cam
3.91 gears, 295/55/15 MT street radials
440 bored .055 over, 4.125 stroker crank
power steering,brakes
hedman headers 1 3/4 primary tubes
1.615 60ft
7.444 1/8
11.76 1/4 112.64
shifting at 5500
calt 2335, bar 29.74, hum 43%
Re: how fast with steel head 440 and hydraulic cam [Re: TheOtherDodge] #1650085
07/24/14 10:29 PM
07/24/14 10:29 PM
superwrench Offline
superwrench  Offline
Yeh... I was just putting my 2 cents worth in about the fact that steel heads are not usually the best way to go. Been there and done that. I had 452 steelies ported and they DID work good. The Eddy's smartened the engine right up.
Re: how fast with steel head 440 and hydraulic cam [Re: superwrench] #1650086
07/25/14 12:04 AM
07/25/14 12:04 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Steel heads suck they flow poorly they tend to crack and so on. Oh happy days now we have lots of aluminum to pick from better performance way less fuel I have not run race gas since I went aluminum.
Re: how fast with steel head 440 and hydraulic cam [Re: Dodgem] #1650087
07/30/14 11:39 AM
07/30/14 11:39 AM
an8sec70cuda Offline
11.40 at 117.4 mph.
440 w/ 915s, 509/292 purpleshaft, Edelbrock performer rpm intake, 4.10 gear, 28x10.5, 3700 lbs. through the mufflers.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: how fast with steel head 440 and hydraulic cam [Re: mcat4321] #1650088
07/30/14 12:42 PM
07/30/14 12:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
a friend of mine has a 71 roadrunner with 440,iron heads, 6 pack set up,410 gear and solid roller 248@50 pump gas. car weights 4000 with him and ran a best of 11.77@117.
Re: how fast with steel head 440 and hydraulic cam [Re: mopar dave] #1650089
07/30/14 09:03 PM
07/30/14 09:03 PM
USA
N
Nitrofish Offline
Nitrofish  Offline
N
USA
69 B-Body
440 with 906 heads
6-pack
509 purple shaft
727 3500 10" Turbo Action
4.10 with slicks
11.66 ET at 119mph.... Forget the exact MPH but he ET is accurate
Have FUN!!
Re: how fast with steel head 440 and hydraulic cam [Re: Nitrofish] #1650090
07/30/14 09:06 PM
07/30/14 09:06 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
3600 lbs 1968 GTX
440
(906) heads
Isky .590 cam
Weiend single plane
4.56 8-3/4
250hp NOS
10.19 @ 137mph
