Re: 99 Ram engine warning light on
[Re: beerwolf]
#1649860
07/22/14 10:44 PM
07/22/14 10:44 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Yeah the code just tells you the cyl is misfiring.Its typically wires or plugs.They also have problems with the plenimum gaskets.It squishes out and sucks oil.Just did one on the 99 Durango.Guessing as to what it is can cost a lot unless you get luck with a bad plug or wires.Could also be cap and or rotor.Rocky
Chrysler Firepower
[Re: beerwolf]
#1649861
07/22/14 10:57 PM
07/22/14 10:57 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep, start with the easy stuff first. Look at the plug first. How old are they??
Go from Plug, plug wire, coil, then injector. Does the 99 ram even have a rotor. The chevys and fords dont of that era.
Im a mopar guy but have never worked on the 99 mopar stuff. Lots of chevys and fords. Fords are COP coil over plug,no wire, chevys have a coil for each cyl plus a wire.
Like said, the pute just detects a misfire, could be a number of things. Start with the easy stuff.
[Re: beerwolf]
#1649864
07/26/14 12:25 PM
07/26/14 12:25 PM
therocks
Niles , Ohio
Thats your first problem Bosch plugs.In 30 years as a mechanic I saw one car that ran good with them.I probally replaced a few thousand because they ran like s--t.Use Champions or NGKs or Autolites.I run NGKs now in everything.Yeah one person in 200 might say Boschs run Ok.But they need to bet the lottery.Rocky
Chrysler Firepower
[Re: beerwolf]
#1649865
07/27/14 12:26 AM
07/27/14 12:26 AM
Sport440
Canton, Ohio
Could be as simple as Old plugs. Or lean on that cylinder from a slightly plugged injector. But, ive seen that on two motors that havent had the plugs changed until 120000 miles. The electrodes were nearly all burnt off on alot of the plugs, not just one. trucks still ran but with a occasional miss when damp out. Time to change all of your plugs. If plugs had low miles on them, injector IMO. So just how old are your plugs in this ride??
[Re: beerwolf]
#1649868
07/27/14 11:35 AM
07/27/14 11:35 AM
therocks
Niles , Ohio
Like I said.Toss the Boschs in the trash and get some good plugs.Most parts stores push them because they get/or did get a kickback from Bosch for selling their garbage.Rocky
Chrysler Firepower
[Re: therocks]
#1649870
07/27/14 12:04 PM
07/27/14 12:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Horse Pucky...Champions!, now that's junk, I'd buy NGK's if nothing else was in stock, I just tuned up one of my DD's a 99 Ram, Bosch plugs/wires on it with 7 years, 90,000 miles on the last set of plugs, the trucks a beater and treated as such, the new set of Bosch platniums/wires should last another 100K
We've been down this slippery slope before about Bosch Platniums,..I run NOTHING but Bosch Platniums in the DD's and the toys, from SmBlks to BBlks to HEMIs....I couldn't fathom the number of fouled Champions/Autolites/NGK's I've pulled from vehicles in over 40 years of wrenching...
The OP most likely needs to freshen up any ignition components that have been neglected over time, perhaps something as simple as a wire set?
[Re: DAYCLONA]
#1649872
07/27/14 12:55 PM
07/27/14 12:55 PM
therocks
Niles , Ohio
Dayclona like I said if they run good go buy Lotto tickets.You are one of the blessed and lucky ones.I was a tech for 30 years.I pulled thousands of Boschs because they ran like s--t and caused misfires etc.Ill have you talk to my buddy that put a set in his Buick.Eight bucks a plug and had a bad miss and ran like crap.New ACs and it still runs great today.30 years I had one car that ran good with them.Let alone put them on a scope and watch the patterns and firing voltages.Rocky
Chrysler Firepower
[Re: beerwolf]
#1649873
07/27/14 12:57 PM
07/27/14 12:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
New plugs wires cap and rotor. Time will tell.
Hopefully you installed quality components, as a lot of "valuecraft" or "economy" brand tune up parts are just pure crap nowadays
[Re: DAYCLONA]
#1649874
07/27/14 01:04 PM
07/27/14 01:04 PM
therocks
Niles , Ohio
Just did the cap and rotor on my kids 99 Durango.I bought it with 19K and now close to 100.We did the intake last week.Used Standard cap and rotor.The OE ones were still decent.Its easy to change them when the intake is off.I hope you used a dab on antisieze on the cap screws and diaelectric on the terminals.Rocky
Chrysler Firepower
