Re: Question about my rear drum brakes
[Re: ProSport]
#1649768
07/22/14 06:06 PM
07/22/14 06:06 PM
RapidRobert
Not a dumb Q at all. Shorter rods (brake nails) I would assume. 8&3/4 SBP rear uses shallow SBP specific backing plates/1&3/4" shoes/drums. the convex side goes inward on the dime sized round holddown spring retainers
[Re: ProSport]
#1649770
07/22/14 06:31 PM
07/22/14 06:31 PM
RapidRobert
Likely you could cut yours then tamp the end(s) flat. As you know measure twice/cut once
[Re: stumpy]
#1649773
07/22/14 08:44 PM
07/22/14 08:44 PM
RapidRobert
I googled em to see if the length was listed & it was not but in the pics the swedge on the end looks pretty healthy & not sure you could get it that wide with a hammer & as Stump said it might be the easiest to just hit your parts store. They're certainly cheap enough
[Re: stumpy]
#1649774
07/22/14 09:47 PM
07/22/14 09:47 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Why go to summit when you can go to the local parts store and get the same thing for a lot less.
Yea they probably sell them everywhere, I have to go to Summit and it's only $2.97 for a box of 4 which is all I need.
I don't know why they don't list the lengths, it would make things easier, I might end up having them bring out a bunch of boxes to find some shorter ones.
[Re: ProSport]
#1649775
07/23/14 07:28 AM
07/23/14 07:28 AM
Posts: 1,357 central Florida
VL21
central Florida
Likely you were just given a kit for 10x2" brakes ... which was (obviously) wrong. Looks like the self adjuster cable has slack in it?
It takes gasoline to interest me.
[Re: VL21]
#1649776
07/23/14 08:05 AM
07/23/14 08:05 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
I had the same problem on my dart. Turns out the kit I had was designed for both sizes of shoes. It came with longer nails and short ones. I found out almost the hard way as the drum nearly ate through the spring retainer!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#1649777
07/23/14 11:36 AM
07/23/14 11:36 AM
RapidRobert
Looking at the pic again it sure looks like the hold down springs ain't close enough to coil bind which they should be somewhat closer to it as the shoes need to be held in there pretty tight
[Re: GTSDart340]
#1649780
07/24/14 11:25 AM
07/24/14 11:25 AM
ProSport
Akron, Ohio
We did these rear drums a year ago, car has been sitting. I found the shorter hold down pins in the bag on my shelf. Everything is much better now.
