B1 COMBOS #1649555
07/22/14 01:59 AM
07/22/14 01:59 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
I would like to hear of some of your B1 combos as far as comp, cam ,rpms
did you use a stock rb block ,what ci
what headers did you use, size pipes and collecters ,made you own
thanks
1.39 9.85 - 137 mph
Re: B1 COMBOS [Re: Ari440] #1649556
07/22/14 03:10 AM
07/22/14 03:10 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Mine was a stock block making around 850 hp or so. 12.5-1 2 1/8th headers untill I could make a bigger set. 797/816 lift turning 8k with aluminum rods and a girdle.
Now I am doing an aluminum block 15-1 comp advanced to 112 c/l 114 lobe sep. instead of 114 with 2 3/8th chassis headers 4.5 x 4.5 engine. I will be done with it in about a month from now. I did some chassis changes , and also need new slicks. Last time out, with the stock block engine, I went a 1.56 60' 6.17 1/8 at 121 mph. that was an intersting run. I plan on shifting somewhere around 7600 or less. no dyno time just tuning it by track times is all.
Re: B1 COMBOS [Re: Ari440] #1649557
07/22/14 10:25 AM
07/22/14 10:25 AM
ohio
top comp Offline
top comp  Offline
ohio
thanks
529 inch KB block,B-1 heads(of course) 1471 blower,carbon injector,crane roller( big) bruno drive and a 3sp lenco.4.29 gear zoomies, and 13 1/2 " MT tires/ shifting at 84 to 8,600 = .901 60ft,3.78 1/8th and 5.92 in the 1/4 engine built by scott koffel
Re: B1 COMBOS [Re: top comp] #1649558
07/22/14 12:04 PM
07/22/14 12:04 PM
NW Indiana
fbs63 Online content
fbs63  Online Content
NW Indiana
557 Indy Maxx block,4.500 bore, 4.375 stroke, 14.8 comp,7.100 rods, custom cam 281-292 @ .050, .860-.812 lift, 112 lobe sep, single 1250 Dom with billet metering plates. Made 978 on an accurate dyno, went 8.84 @ 153 in a 3200# car on 10.5x29.5 with ladder bars. I'm sure it still had more in it.
Re: B1 COMBOS [Re: Ari440] #1649559
07/22/14 01:34 PM
07/22/14 01:34 PM
Finland
LUMI Offline
LUMI  Offline
Finland
B1 originals, B1 Intake, Venolia 4.5 pistons, Callies 4.77 Crank, 6.8" H beam Rods, Koleno KP440 Block, 1270cfm AED Max Pro Dominator, Crane Mec Roller 320/328deg 114 disp angle int .79 ex .76 CR10.69
TTI 2.0/ 2 1/8 /3.5 Headers
dynoed 942@6100 and 886@5100 at Koffels Place with 1050 Dominator
Full streetcar not on a strip yet, but first run in 2 weeks
Re: B1 COMBOS [Re: LUMI] #1649560
07/22/14 01:54 PM
07/22/14 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just curious but what`s w/all of these wide lsa`s...........is it to take advantage of the upper rpm capabilities?
Re: B1 COMBOS [Re: Thumperdart] #1649561
07/22/14 02:25 PM
07/22/14 02:25 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I don't know what cam is in the KOS 499 but that thing will rev - and rev right now! .900 lift. I think the heads are B1MC not PSO judging from what Monte said a PSO head looks like.
Like MoparAl's, the headers are also interesting.
Re: B1 COMBOS [Re: Thumperdart] #1649562
07/22/14 03:52 PM
07/22/14 03:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cause it works...Free your mind
Re: B1 COMBOS [Re: Al_Alguire] #1649563
07/22/14 03:54 PM
07/22/14 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I freed my mind years ago on mushrooms petting Mojave rattlesnakes............So, it must have something to do with the broad rpm range yes?
Re: B1 COMBOS [Re: Thumperdart] #1649564
07/22/14 06:46 PM
07/22/14 06:46 PM
gregsdart Offline
gregsdart  Offline
I looked at four different grinds recommended for my combo with 2 at 110 LSA and 2 at 112 LSA. The lobe separation got wider to accommodate the longer exhaust durations of the cams with the 112 LSA. On all four cams the intake closing point was close to the same, the overlap was close to the same with the exhaust closing and intake opening being close to the same. The difference was the exhaust opening point. The more exhaust duration, the wider the LSA to keep three out of four of the valve events in about the same spot.
Re: B1 COMBOS [Re: gregsdart] #1649565
07/22/14 10:44 PM
07/22/14 10:44 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
I pick up a set of heads P4349600
set of valvecovers
black rockerarms with shafts and mounting blocks but they are water damaged and rusted
no valves springs retainers
cast tunnelram two 1050 early style the linkage say,s S-M SOX & MARTIN
1969 440 short block need to take it apart
how do I know if there B1 pistons
rollarcam don't know specs yet no lifters
aftermarket rods
don't know if its a stroked motor
milidon duel oillines on a dragster oilpan
tach drive distributer and B&M flex plate
8 inch ATI converter with 727 tannie
1.39 9.85 - 137 mph
Re: B1 COMBOS [Re: Ari440] #1649566
07/23/14 01:31 AM
07/23/14 01:31 AM
NW Indiana
NW Indiana
B1 pistons will have DEEP notches. Also the notches are centered on the bore. You can also measure the dia. of the valve pockets Should be 2.400 and 1.900 or close to it. The best way to check is mock it up.
Re: B1 COMBOS [Re: Ari440] #1649567
07/23/14 08:17 AM
07/23/14 08:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Is this a B1 casting #?^^^
Re: B1 COMBOS [Re: racerx] #1649568
07/23/14 11:09 AM
07/23/14 11:09 AM
NW Indiana
NW Indiana
At one time B1s sold thru Mopar Performance and had a Mopar PN. I imagine that's the old PN.
Re: B1 COMBOS [Re: fbs63] #1649569
07/23/14 11:13 AM
07/23/14 11:13 AM
NW Indiana
NW Indiana
I would check out the list #s on the carbs. If they say S&M they are likely individual runner carbs. Calibrated very differently than a plenum style carb.
Re: B1 COMBOS [Re: gregsdart] #1649570
07/23/14 11:58 AM
07/23/14 11:58 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx Greg...............learn sumptin everyday.
Re: B1 COMBOS [Re: Thumperdart] #1649571
07/24/14 11:39 PM
07/24/14 11:39 PM
duluth,mn
P
psycomopar Offline
psycomopar  Offline
P
duluth,mn
605 world block b1 heads little porting to them. Comp cam speced by Chuck at best machine for my old 512. Could probably use a different cam. Something like i think .813 lift 308 duration and installed at 112. Prosystems 1050. And way small 2" fenderwell headers. Haven't found a set of headers yet. dynoed at 965 hp and I believe 845 tq.
Re: B1 COMBOS [Re: Al_Alguire] #1649572
07/25/14 11:13 PM
07/25/14 11:13 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
what was your combo in the valiant AL
1.39 9.85 - 137 mph
Re: B1 COMBOS [Re: Ari440] #1649573
07/26/14 09:28 PM
07/26/14 09:28 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
1.39 9.85 - 137 mph
Re: B1 COMBOS [Re: Ari440] #1649574
07/26/14 09:29 PM
07/26/14 09:29 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
1.39 9.85 - 137 mph
