B1 COMBOS
#1649555
07/22/14 01:59 AM
07/22/14 01:59 AM
Posts: 5,619 long island NY
Ari440
long island NY
I would like to hear of some of your B1 combos as far as comp, cam ,rpms
did you use a stock rb block ,what ci
what headers did you use, size pipes and collecters ,made you own
thanks
1.39 9.85 - 137 mph
Re: B1 COMBOS
[Re: Ari440]
#1649557
07/22/14 10:25 AM
07/22/14 10:25 AM
Posts: 27 ohio
top comp
ohio
thanks
529 inch KB block,B-1 heads(of course) 1471 blower,carbon injector,crane roller( big) bruno drive and a 3sp lenco.4.29 gear zoomies, and 13 1/2 " MT tires/ shifting at 84 to 8,600 = .901 60ft,3.78 1/8th and 5.92 in the 1/4 engine built by scott koffel
Re: B1 COMBOS
[Re: top comp]
#1649558
07/22/14 12:04 PM
07/22/14 12:04 PM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
557 Indy Maxx block,4.500 bore, 4.375 stroke, 14.8 comp,7.100 rods, custom cam 281-292 @ .050, .860-.812 lift, 112 lobe sep, single 1250 Dom with billet metering plates. Made 978 on an accurate dyno, went 8.84 @ 153 in a 3200# car on 10.5x29.5 with ladder bars. I'm sure it still had more in it.
Re: B1 COMBOS
[Re: Ari440]
#1649559
07/22/14 01:34 PM
07/22/14 01:34 PM
Posts: 46 Finland
LUMI
Finland
B1 originals, B1 Intake, Venolia 4.5 pistons, Callies 4.77 Crank, 6.8" H beam Rods, Koleno KP440 Block, 1270cfm AED Max Pro Dominator, Crane Mec Roller 320/328deg 114 disp angle int .79 ex .76 CR10.69 TTI 2.0/ 2 1/8 /3.5 Headers dynoed 942@6100 and 886@5100 at Koffels Place with 1050 Dominator Full streetcar not on a strip yet, but first run in 2 weeks
Re: B1 COMBOS
[Re: gregsdart]
#1649565
07/22/14 10:44 PM
07/22/14 10:44 PM
Ari440
long island NY
I pick up a set of heads P4349600
set of valvecovers
black rockerarms with shafts and mounting blocks but they are water damaged and rusted
no valves springs retainers
cast tunnelram two 1050 early style the linkage say,s S-M SOX & MARTIN
1969 440 short block need to take it apart
how do I know if there B1 pistons
rollarcam don't know specs yet no lifters
aftermarket rods
don't know if its a stroked motor
milidon duel oillines on a dragster oilpan
tach drive distributer and B&M flex plate
8 inch ATI converter with 727 tannie
1.39 9.85 - 137 mph
Re: B1 COMBOS
[Re: Thumperdart]
#1649571
07/24/14 11:39 PM
07/24/14 11:39 PM
Posts: 509 duluth,mn
psycomopar
duluth,mn
605 world block b1 heads little porting to them. Comp cam speced by Chuck at best machine for my old 512. Could probably use a different cam. Something like i think .813 lift 308 duration and installed at 112. Prosystems 1050. And way small 2" fenderwell headers. Haven't found a set of headers yet. dynoed at 965 hp and I believe 845 tq.
