Re: 1971 plymouth duster heat problem
#164931
12/09/08 04:10 PM
12/09/08 04:10 PM
RapidRobert
Possibilities: the air blend doors could not be opened all the way, heater hoses on backwards, heater core partly plugged.
[Re: RapidRobert]
#164932
12/09/08 04:14 PM
12/09/08 04:14 PM
Where are the Air blend doors located ? and how would i close it, if its opened.
#164933
12/09/08 04:22 PM
12/09/08 04:22 PM
RapidRobert
in the heater box under the dash. they are either cable or vac pod activated. There's 2 doors & manually move them & see if that takes care of you.
[Re: RapidRobert]
#164934
12/09/08 04:25 PM
12/09/08 04:25 PM
Well there was a door under the passenger side dash with a little lever connected to it that was open last time. i closed that and the heat was hot. But then it got cool again. Where is the 2nd door ?
#164935
12/09/08 04:31 PM
12/09/08 04:31 PM
RapidRobert
Look for where the other cable connects to. one door directs air up to the defroster vents & the other door being opened a certain amt dilutes the amt of hot air for temperature control.
[Re: RapidRobert]
#164936
12/09/08 04:35 PM
12/09/08 04:35 PM
Yea the 1 i closed i had to tape close. It goes somewhere to the controls in the dash. But i have no clue where to even start looking for the 1 you are speaking about. What is amt ? and where should i look ?
#164937
12/09/08 04:41 PM
12/09/08 04:41 PM
RapidRobert
the other one is more hidden somewhat but it is in the black heater box there. Can you trace the other control cable(the temperature lever) from the dash down to the box & open it all one way then all the other way & see if one of those makes it heat up.
[Re: RapidRobert]
#164938
12/09/08 04:52 PM
12/09/08 04:52 PM
Well what happened was the heat use to come out cool. So i closed that vent with the lever going up to the dash with tape and the heat got really warm. I was driving the other day and im guessing the tape came loose and the heat got cool again. I reset the tape so the vent was closed it got hot again and then out of no where cool. I checked the vent and its still closed.
[Re: RapidRobert]
#164940
12/09/08 04:59 PM
12/09/08 04:59 PM
#164941
12/09/08 05:03 PM
12/09/08 05:03 PM
RapidRobert
I started to celebrate too soon. can you see where the other cable goes to(from the temperature lever) & move that door
[Re: RapidRobert]
#164942
12/09/08 05:05 PM
12/09/08 05:05 PM
The only thing i see is the 1 with the lever that goes from the vent to the dash somewhere. The lever is medal. It goes to 1 of the controls in the dash. Thats the 1 i closed. I dont see the other 1 u speak of.
#164943
12/09/08 05:10 PM
12/09/08 05:10 PM
RapidRobert
This car has no A/C right? On the dash there's 2 heater controls, does one says off-heat-defrost & the other says temp & you can slide it all the way over? & if not what do you have?
[Re: RapidRobert]
#164944
12/09/08 05:13 PM
12/09/08 05:13 PM
Yes that is correct. No there isnt AC. I have the Temperature thing all the way to warm and i have 2 dash bottons pressed in. defrost and heat if that helps.
#164945
12/09/08 05:30 PM
12/09/08 05:30 PM
RapidRobert
with the temp lever all the way over to warm then the DOOR thats moved by that cable needs to be moved all the way over(not sure which way) & since you have DEF & HEAT buttons you dont have a second lever, the buttons direct vacuum to a vac pod on the outside of the door that moves the door open & closed or to a vacuum valve under the hood in one of the heater hoses It will have at least 1 small dia vac line going to it.
[Re: 70Duster440]
#164947
12/09/08 06:10 PM
12/09/08 06:10 PM
RapidRobert
tremendously helpful. I thought there was 2 cables EDIT that only A/C had the vac pods on the heater box with the possible exception that A/C/non A/C both had the vacuum controlled shutoff valve in one of the heater hoses on the passenger inner fender under the hood.
#164949
12/09/08 07:55 PM
12/09/08 07:55 PM
RapidRobert
Rereading this I think Dmerc is right the core is plugged, if it went from hot back to cold & the door(s) stayed untouched & that drastic of a change means a piece of crud came loose & blocked it rather than a slow buildup reducing flow so you might take the hoses off the firewall & backflush it with a garden hose which might push that piece out of there or shift it out of the way.
