1971 plymouth duster heat problem #164930
12/09/08 04:01 PM
12/09/08 04:01 PM
Anonymous OP
Anonymous OP
Hey guys. I have a 1971 Plymouth duster with a 340. The heat comes in cool/luke warm. I have a 180 thermastat in it. The coolant level is up to level too. What is making this come out cool? The fan blows just fine, its just the air is cool no matter how warmed up the car is. Any suggestions ?
Re: 1971 plymouth duster heat problem #164931
12/09/08 04:10 PM
12/09/08 04:10 PM
Possibilities: the air blend doors could not be opened all the way, heater hoses on backwards, heater core partly plugged.
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164932
12/09/08 04:14 PM
12/09/08 04:14 PM
Anonymous OP
Anonymous OP
Where are the Air blend doors located ? and how would i close it, if its opened.
Re: 1971 plymouth duster heat problem #164933
12/09/08 04:22 PM
12/09/08 04:22 PM
in the heater box under the dash. they are either cable or vac pod activated. There's 2 doors & manually move them & see if that takes care of you.
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164934
12/09/08 04:25 PM
12/09/08 04:25 PM
Anonymous OP
Anonymous OP
Well there was a door under the passenger side dash with a little lever connected to it that was open last time. i closed that and the heat was hot. But then it got cool again. Where is the 2nd door ?
Re: 1971 plymouth duster heat problem #164935
12/09/08 04:31 PM
12/09/08 04:31 PM
Look for where the other cable connects to. one door directs air up to the defroster vents & the other door being opened a certain amt dilutes the amt of hot air for temperature control.
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164936
12/09/08 04:35 PM
12/09/08 04:35 PM
Anonymous OP
Anonymous OP
Yea the 1 i closed i had to tape close. It goes somewhere to the controls in the dash. But i have no clue where to even start looking for the 1 you are speaking about. What is amt ? and where should i look ?
Re: 1971 plymouth duster heat problem #164937
12/09/08 04:41 PM
12/09/08 04:41 PM
the other one is more hidden somewhat but it is in the black heater box there. Can you trace the other control cable(the temperature lever) from the dash down to the box & open it all one way then all the other way & see if one of those makes it heat up.
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164938
12/09/08 04:52 PM
12/09/08 04:52 PM
Anonymous OP
Anonymous OP
Well what happened was the heat use to come out cool. So i closed that vent with the lever going up to the dash with tape and the heat got really warm. I was driving the other day and im guessing the tape came loose and the heat got cool again. I reset the tape so the vent was closed it got hot again and then out of no where cool. I checked the vent and its still closed.
Re: 1971 plymouth duster heat problem #164939
12/09/08 04:56 PM
12/09/08 04:56 PM
& its hot
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164940
12/09/08 04:59 PM
12/09/08 04:59 PM
Anonymous OP
Anonymous OP
No its cool now. = /
Re: 1971 plymouth duster heat problem #164941
12/09/08 05:03 PM
12/09/08 05:03 PM
I started to celebrate too soon. can you see where the other cable goes to(from the temperature lever) & move that door
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164942
12/09/08 05:05 PM
12/09/08 05:05 PM
Anonymous OP
Anonymous OP
The only thing i see is the 1 with the lever that goes from the vent to the dash somewhere. The lever is medal. It goes to 1 of the controls in the dash. Thats the 1 i closed. I dont see the other 1 u speak of.
Re: 1971 plymouth duster heat problem #164943
12/09/08 05:10 PM
12/09/08 05:10 PM
This car has no A/C right? On the dash there's 2 heater controls, does one says off-heat-defrost & the other says temp & you can slide it all the way over? & if not what do you have?
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164944
12/09/08 05:13 PM
12/09/08 05:13 PM
Anonymous OP
Anonymous OP
Yes that is correct. No there isnt AC. I have the Temperature thing all the way to warm and i have 2 dash bottons pressed in. defrost and heat if that helps.
Re: 1971 plymouth duster heat problem #164945
12/09/08 05:30 PM
12/09/08 05:30 PM
with the temp lever all the way over to warm then the DOOR thats moved by that cable needs to be moved all the way over(not sure which way) & since you have DEF & HEAT buttons you dont have a second lever, the buttons direct vacuum to a vac pod on the outside of the door that moves the door open & closed or to a vacuum valve under the hood in one of the heater hoses It will have at least 1 small dia vac line going to it.
Re: 1971 plymouth duster heat problem #164946
12/09/08 06:03 PM
12/09/08 06:03 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Re: 1971 plymouth duster heat problem [Re: 70Duster440] #164947
12/09/08 06:10 PM
12/09/08 06:10 PM
tremendously helpful. I thought there was 2 cables EDIT that only A/C had the vac pods on the heater box with the possible exception that A/C/non A/C both had the vacuum controlled shutoff valve in one of the heater hoses on the passenger inner fender under the hood.
Re: 1971 plymouth duster heat problem [Re: RapidRobert] #164948
12/09/08 06:19 PM
12/09/08 06:19 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
My 71 Does not have any vacuum lines going anywhere. It's all cable actuated. Sounds like your heater core is plugged.
Re: 1971 plymouth duster heat problem #164949
12/09/08 07:55 PM
12/09/08 07:55 PM
Rereading this I think Dmerc is right the core is plugged, if it went from hot back to cold & the door(s) stayed untouched & that drastic of a change means a piece of crud came loose & blocked it rather than a slow buildup reducing flow so you might take the hoses off the firewall & backflush it with a garden hose which might push that piece out of there or shift it out of the way.
