"Problem Solver" Ball Joints #1648920
07/20/14 10:37 PM
07/20/14 10:37 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I'm getting my volare back on the road and it's in need of an alignment. I've had it aligned twice in the past & it's a bear to get the top of the tire far enough out. It's fallen back in twice now on both sides. A buddy mentioned switching to the Moog "Problem Solver" upper ball joint which he says will give me some "built in" camber.
Just want to see if anyone has done this with success or have other thoughts/ideas.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648921
07/20/14 10:51 PM
07/20/14 10:51 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I know they worked on Chevettes.You fliped them one way or the other to get more or less camber.I did a lot of them at work.Never heard of them for Mopars.Only way camber can change is if the adjustment bolts arent tight.My nephew had his done and they didnt tighten them enough.Rocky
Chrysler Firepower
Re: "Problem Solver" Ball Joints [Re: therocks] #1648922
07/20/14 11:03 PM
07/20/14 11:03 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Ya, I'm not really sure either as they're screw in uppers so how would you locate them properly. Rock Auto has them listed as Moog K772 problem solver for only $14.99.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648923
07/20/14 11:53 PM
07/20/14 11:53 PM
isn't it Moog offset UCA bushings #K7103 & they will kick the UCA/top of spindle out to get more positive camber. I would first check into getting the frame tabs welded so it wont cave in again.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648924
07/21/14 12:01 AM
07/21/14 12:01 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
He's not working on Mopars if he says upper ball joints will give you more camber , they're screw in types as mentioned, only offset bushings UCA bushings can do that. BTW all Moog parts say "problem solver " on the box.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648925
07/21/14 12:04 AM
07/21/14 12:04 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
My 76 F gets plenty of camber. You mention its "fallen back in". Do you mean the dog bone (shaft the uca pivots on) has moved after alignment?
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648926
07/21/14 12:21 AM
07/21/14 12:21 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes the Moog "problem solver" upper control arm bushings work.
Never heard of Ball joint problem solvers. Im sure your referring to the upper control arm bushings. The bushings have a Offset hole for the bushing bolt vs centered for a stock bushing. They work.
As far as your camber slipping back in. your adjuster bolts werent tightend enough and slipped or your shock tower is rusted and flexing in from bumps and lack of strength. Or your lower control arm bushings are shot and moving out. The Volaries had alot of extra rubber in thier Kframes
Re: "Problem Solver" Ball Joints [Re: Sport440] #1648927
07/21/14 05:32 AM
07/21/14 05:32 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Most often Moog problem solvers are just reengineered to fix common failure points. They don't always have anything to do with alignments.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: "Problem Solver" Ball Joints [Re: GTSDart340] #1648928
07/21/14 09:27 AM
07/21/14 09:27 AM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Thanks for clearing that up. I looked into offset bushings but the moog pic shows them centered. May have to see if the parts store can get a set for me to check out.
As far as the top falling back in, Nothings rusted & we used an impact gun both times. Car's in pretty good shape with only 45k on the clock. I'll do some more digging on the car to see if I can find the issue.
Re: "Problem Solver" Ball Joints [Re: formula_s] #1648929
07/21/14 01:01 PM
07/21/14 01:01 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I noticed that as well.
FWIW, the "Problem solver" upper bushings won't work on F bodies because they have a shaft mounted upper control arm and do not use the same eccentric cams as old mopars. If the upper arms are moving, I'd think the bolts are striped or the serrated tines are stripped or there is some other physical problem with the set up.
Re: "Problem Solver" Ball Joints [Re: TC@HP2] #1648930
07/21/14 02:57 PM
07/21/14 02:57 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I think the serrations are worn out on the shafts but it was always tough to get the top of the tire out far enough. Usually maxed out with a pry bar while gunning the bolts down. I was really hoping I could get a little more camber in it before taking it down to the shop.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648931
07/21/14 05:30 PM
07/21/14 05:30 PM
dogdays Offline
dogdays  Offline
From the looks of drawings i found online, the upper A-arms are on shafts with the shafts bolted down with vertical bolts. So the alignment method of adding or subtracting spcers behind the shaft won't work.
You could slot the holes to gain more adjustability. It's been done a lot on MacPherson strut upper bearing mounts, although they don't see the forces that the shaft holddown bolts do. Still, you should be able to make some changes.
R.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648932
07/21/14 07:19 PM
07/21/14 07:19 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
How much camber are you trying to get...don't use the old bias tires specs. If you can get to -.25 or -.50 you're golden with as much pos. caster as possible. Make sure those upper control arm bolts are clean and tight!!! I've had them move on me before!! I spent a lot of time in the alignment pit when these things were on the road all the time.
Re: "Problem Solver" Ball Joints [Re: dogdays] #1648933
07/21/14 09:36 PM
07/21/14 09:36 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Widening the slots sounds like it might be the easiest option. Going to pull the bolts out & check the serrations out. New shafts may be in order if they're worn off. That's if they're even available. It's been several years since I've played with this car so things are a little foggy.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648934
07/21/14 09:38 PM
07/21/14 09:38 PM
Did you check the torque specs? Whats the condition of the UCA and LCA bushings?
I wouldnt use an air gun on the UCA shaft hold down bolts. Torque them down to 150 ft lbs.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648935
07/21/14 09:46 PM
07/21/14 09:46 PM
The serrations are on both the shaft and the plate they mount to.
Re: "Problem Solver" Ball Joints [Re: nomore65BelvJim] #1648936
07/22/14 05:10 PM
07/22/14 05:10 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Thanks Jim for the torque spec & pic. Everything was nice when I put the car together but I put it away when I bought a house. Just getting it out after nearly 7 years. Got to definitely go thru the front end before I waste any more money on another alignment.
Re: "Problem Solver" Ball Joints [Re: 80fbody] #1648937
07/22/14 05:41 PM
07/22/14 05:41 PM
Your welcome Jay.
I rebuilt the front end on my 76 Aspen wagon last year. UCA bushings were whipped and actually falling apart on the PS. Camber was visibly off on that side.
RockAuto had everything I needed to rebuild, all MOOG and TRW, and at very good prices.
