Re: "Problem Solver" Ball Joints
[Re: 80fbody]
#1648921
07/20/14 10:51 PM
07/20/14 10:51 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I know they worked on Chevettes.You fliped them one way or the other to get more or less camber.I did a lot of them at work.Never heard of them for Mopars.Only way camber can change is if the adjustment bolts arent tight.My nephew had his done and they didnt tighten them enough.Rocky
Chrysler Firepower
[Re: therocks]
#1648922
07/20/14 11:03 PM
07/20/14 11:03 PM
Posts: 596 Mass.
80fbody
Mass.
Ya, I'm not really sure either as they're screw in uppers so how would you locate them properly. Rock Auto has them listed as Moog K772 problem solver for only $14.99.
[Re: 80fbody]
#1648923
07/20/14 11:53 PM
07/20/14 11:53 PM
RapidRobert
isn't it Moog offset UCA bushings #K7103 & they will kick the UCA/top of spindle out to get more positive camber. I would first check into getting the frame tabs welded so it wont cave in again.
[Re: 80fbody]
#1648924
07/21/14 12:01 AM
07/21/14 12:01 AM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
both sides. A buddy mentioned switching to the Moog "Problem Solver" upper ball joint which he says will give me some "built in" camber.
He's not working on Mopars if he says upper ball joints will give you more camber , they're screw in types as mentioned, only offset bushings UCA bushings can do that. BTW all Moog parts say "problem solver " on the box.
[Re: 80fbody]
#1648925
07/21/14 12:04 AM
07/21/14 12:04 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
I'm getting my volare back on the road and it's in need of an alignment. I've had it aligned twice in the past & it's a bear to get the top of the tire far enough out. It's fallen back in twice now on both sides. A buddy mentioned switching to the Moog "Problem Solver" upper ball joint which he says will give me some "built in" camber.
Just want to see if anyone has done this with success or have other thoughts/ideas.
My 76 F gets plenty of camber. You mention its "fallen back in". Do you mean the dog bone (shaft the uca pivots on) has moved after alignment?
[Re: formula_s]
#1648929
07/21/14 01:01 PM
07/21/14 01:01 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I noticed that as well.
FWIW, the "Problem solver" upper bushings won't work on F bodies because they have a shaft mounted upper control arm and do not use the same eccentric cams as old mopars. If the upper arms are moving, I'd think the bolts are striped or the serrated tines are stripped or there is some other physical problem with the set up.
[Re: 80fbody]
#1648932
07/21/14 07:19 PM
07/21/14 07:19 PM
Posts: 4,946 WI
Dcuda69
WI
[Re: 80fbody]
#1648934
07/21/14 09:38 PM
07/21/14 09:38 PM
nomore65BelvJim
I think the serrations are worn out on the shafts but it was always tough to get the top of the tire out far enough. Usually maxed out with a pry bar while gunning the bolts down. I was really hoping I could get a little more camber in it before taking it down to the shop.
Did you check the torque specs? Whats the condition of the UCA and LCA bushings? I wouldnt use an air gun on the UCA shaft hold down bolts. Torque them down to 150 ft lbs.
[Re: 80fbody]
#1648935
07/21/14 09:46 PM
07/21/14 09:46 PM
nomore65BelvJim
Widening the slots sounds like it might be the easiest option. Going to pull the bolts out & check the serrations out. New shafts may be in order if they're worn off. That's if they're even available. It's been several years since I've played with this car so things are a little foggy.
The serrations are on both the shaft and the plate they mount to.
[Re: 80fbody]
#1648937
07/22/14 05:41 PM
07/22/14 05:41 PM
nomore65BelvJim
Your welcome Jay. I rebuilt the front end on my 76 Aspen wagon last year. UCA bushings were whipped and actually falling apart on the PS. Camber was visibly off on that side. RockAuto had everything I needed to rebuild, all MOOG and TRW, and at very good prices.
