2006 pacfica front end clunk #1648884
07/20/14 10:15 PM
07/20/14 10:15 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
Hello,
I have couple of questions on wife's 2006 pacifica. The car has a low speed clunk in the front end, and I have inspected it a couple times and the only thing I found is potential excessive end play on the passenger side Axle. Not sure if this is the culprit... Anybody have similar issues diagnosing? Could you tell me how to check if this end play is normal? Any other leads to help me figure this out? I have confirmed the cradle and mounts,sway bar, exhuast and struts are tight and good shape. Any help is appreciated.
Thanks,
Joe
Re: 2006 pacfica front end clunk [Re: Jopar] #1648885
07/20/14 10:27 PM
07/20/14 10:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
On those things, have only heard about bad engine mounts as somewhat common, and rusted through subframes in rustbelt vehicles.
Re: 2006 pacfica front end clunk [Re: buildanother] #1648886
07/20/14 10:47 PM
07/20/14 10:47 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Lower ball joints and inner and outer tie rod ends are common as well. Also, check the spindle nuts for the correct torque.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 2006 pacfica front end clunk [Re: 5wndwcpe] #1648887
07/25/14 01:14 AM
07/25/14 01:14 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
rotted front k-frame common problem, was a recall back then
Re: 2006 pacfica front end clunk [Re: Jopar] #1648888
07/25/14 02:13 AM
07/25/14 02:13 AM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
My dad owned an 04 awd, which developed a bad "snap" when changing directions with the wheels turned (backing out of a driveway/ parking stall was the worst).After a lot of internet searching, I ended up replacing the power transfer unit (basically the transfer case), which fixed the problem. Chrysler had a notice published about this, which called for a couple gaskets/insulators to be installed on the axle shafts. Tried that first, but it didn't make any difference. Hope this helps, good luck.
Re: 2006 pacfica front end clunk [Re: fshd4it] #1648889
07/25/14 09:42 AM
07/25/14 09:42 AM
NJ
rth Offline
rth  Offline
NJ
They also eat up sway bar links.
Re: 2006 pacfica front end clunk [Re: rth] #1648890
07/25/14 11:29 AM
07/25/14 11:29 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
You need to check these with the weight of the vehicle on the wheels, if the suspension is hanging they will appear tight when they are not.
Re: 2006 pacfica front end clunk [Re: Dcuda69] #1648891
07/25/14 11:28 PM
07/25/14 11:28 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Also be sure to check the sway bar bushings the same way. Very common problem.
Have someone rock the vehicle side to side while you look at the bushings for slop.
Re: 2006 pacfica front end clunk [Re: Todd] #1648892
07/26/14 01:49 AM
07/26/14 01:49 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
eats links because the frame is loose/rotted
Re: 2006 pacfica front end clunk [Re: AARCONV] #1648893
07/27/14 11:06 PM
07/27/14 11:06 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
