Sbm turbo headers #1648720
07/20/14 02:31 PM
07/20/14 02:31 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
Anyone know of anyone who builds/sells 318/340/360 single turbo headers or a kit w/ t6 flange . I've looked with no luck.
I'm looking for a semi bolt on deal. Not looking to fabricate a lot, and I know that sounds dumb.
Re: Sbm turbo headers [Re: 1980volare] #1648721
07/20/14 03:09 PM
07/20/14 03:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Find some decent sb Chevy ones and weld Mopar flanges to them would be the route I would take.
Mopar to the bone!!!
Re: Sbm turbo headers [Re: 1980volare] #1648722
07/20/14 04:58 PM
07/20/14 04:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I can't remember when it was, but in a Mopar Muscle (I think) issue there was an advertisement/new product article on a single turbo bolt in deal for the 94-02 rams, maybe someone else will chime in
Re: Sbm turbo headers [Re: 1980volare] #1648723
07/20/14 05:11 PM
07/20/14 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I built dizuster turbo set up we used the magnum
manifolds flipped to the other side so they exited
in the front, then I made up the front Y pipe to get
to the single 76mm turbo.. then I did the rest of the
hot side and the cold side... he is running 10.0 right
now in his 62 4 door Ply... I dont know of any kits
that you can buy
Re: Sbm turbo headers [Re: MR_P_BODY] #1648724
07/20/14 10:49 PM
07/20/14 10:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since turbos and high heat go together, how are the considerable expansion/possible leakage issues handled if SS is used for the exhaust?
Re: Sbm turbo headers [Re: jcc] #1648725
07/20/14 11:09 PM
07/20/14 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never had any issues with SS.. some say it
cracks but if you have expansion joints it souldnt..
if any of the steels cant grow they will crack
Re: Sbm turbo headers [Re: MR_P_BODY] #1648726
07/20/14 11:13 PM
07/20/14 11:13 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well since SS is the worst at high temp growth, what style expansion joint is used and in what areas, that doesn't have leakage issues? I agree, solid restraint would be detrimental and prone to cracking.
Re: Sbm turbo headers [Re: jcc] #1648727
07/21/14 12:48 AM
07/21/14 12:48 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
most use a double slip joint or a stainless bellow. you can use the stainless braided flex couplers as long as there is a bellow inside
Re: Sbm turbo headers [Re: prochargedhemi] #1648728
07/21/14 10:46 AM
07/21/14 10:46 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine has a stainless bellow inside the flex joint. But the ball / socket flanges on the manifolds allow for quite a bit of movement when needed anyway.
No off the shelf kits are available from what I've seen. I even considered duplicating mine to sell... But I think it's too much trouble to mass produce for such a small market.
Re: Sbm turbo headers [Re: dizuster] #1648729
07/21/14 11:22 AM
07/21/14 11:22 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I used some SS shorties and flip them side to side.
Re: Sbm turbo headers [Re: TheOtherDodge] #1648730
07/21/14 12:12 PM
07/21/14 12:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do you have pix of that set-up? My next build might be a short box Gen I Dakota. I was thinking about puting them right be hind the cab in the bed, but If you can just flip them that might be easier.
Re: Sbm turbo headers [Re: Mr.Yuck] #1648731
07/21/14 01:55 PM
07/21/14 01:55 PM
Houston, Texas
Houston, Texas
Not with me at work, but I can take a few when I get home. The only thing we had to do was move the power steering bracket up just a smidge and we did that with a plate.
Re: Sbm turbo headers [Re: TheOtherDodge] #1648732
07/22/14 11:37 AM
07/22/14 11:37 AM
Houston, Texas
Houston, Texas
Here is the driver's side. It is not the greatest and I can take some more this evening if you want and move the car out of the garage for more light.
You can see the 1/4" aluminum plate we used to relocate the PS pump (between the head and pump). The collectors are cut and v-bands welded. It really is a pretty simple swap.
Hope this helps.
Also, I just remembered...I have another set of SS shorties that I bought from someone who cut the collectors and welded v-bands just like you will need to do. I can take a pic of them because they are not on a vehicle. Let me know.
Re: Sbm turbo headers [Re: TheOtherDodge] #1648733
07/22/14 08:10 PM
07/22/14 08:10 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
Just for curiosity's sake, any reason a short 4-2-1 header design couldn't be used?
Danny
Re: Sbm turbo headers [Re: gofish] #1648734
07/23/14 12:06 PM
07/23/14 12:06 PM
Houston, Texas
Houston, Texas
Danny
That would work. Even stock exh manifolds will work. On my build, a true custom tubular headers wouldn't give any advantage over the shorty header that is flipped.
Re: Sbm turbo headers [Re: TheOtherDodge] #1648735
07/23/14 12:58 PM
07/23/14 12:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of shorty header did you start with?
Re: Sbm turbo headers [Re: WO23Coronet] #1648736
07/23/14 01:46 PM
07/23/14 01:46 PM
Houston, Texas
Houston, Texas
I don't know the exact brand as I bought them from some one. Just some stainless shorties much like these: http://www.ebay.com/itm/Manzo-Stainless-...dfb&vxp=mtr
Re: Sbm turbo headers [Re: TheOtherDodge] #1648737
07/23/14 01:51 PM
07/23/14 01:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That is the truth... you guys would laugh if you saw how small the hole is in the turbine itself that all of the exhaust flow goes through.
My manifolds only have a 1 7/8" outlet for all 4 cylinders to flow through, and have supported 700+hp with no issue so far.
I've seen 1000hp plus on stuff a lot worse then the magnum manifolds.
Re: Sbm turbo headers [Re: dizuster] #1648738
07/25/14 10:22 PM
07/25/14 10:22 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Not sure if this will help but here are some I made, not that hard to do. I have a rack so it was easy to go down/forward
Re: Sbm turbo headers [Re: redruM] #1648739
07/28/14 09:16 AM
07/28/14 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here's something I saw a while back..thought it might work.
