Re: Headliner tips
[Re: 340mouse]
#1648550
07/20/14 12:51 PM
07/20/14 12:51 PM
RapidRobert
I've only did one (65 dart). vinyl I'm assuming. Set it out on a blanket in the sun to get some of the wrinkles out. Need a helper. I would suggest working on it over several days or more as it will test your patience & you want most of the wrinkels out before you cut it/install the trim that locks it down tho a hair dryer will remove very slight wrinkles after you are done. The rear sail panel area was the hardest to get smooth. I would suggest some dynamat (or similar) that is thin under there also. take your time
Re: Headliner tips
[Re: RapidRobert]
#1648551
07/20/14 12:56 PM
07/20/14 12:56 PM
Posts: 8,674 Buford, GA
I_bleed_MOPAR
Buford, GA
Like RR, I've only done the one in my sons '71 Charger. Like he said, lay it out in the sun for a while. Label the headliner bows as to location when you remove them. And echoing RR again, take your time. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Headliner tips
[Re: ONEBADBIRD]
#1648553
07/20/14 01:56 PM
07/20/14 01:56 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I just finished the headliner in the Dart. It came out pretty nice. My car has a cage, so that sort of complicated things but some tips:
- Make sure you trim the listing pockets back far enough. Otherwise, you will get wrinkles when you stretch near the seams. I needed to go back and trim mine back multiple times and at that I still think I could have gone further. - Lay it out in the sun, some guys take a steamer or clothes iron with a towel to the fold marks. Mine has been out of the box in a while, and I had it in the sun a few times. Either way, not critical, those marks will eventually come out. - Start front to back, center/center, then do sides front to back (how I did mine anyway). - I went to Harber Freight and bought a bunch of the 99 cent claps with red dipped tips/handles. - Use brush on glue/contact cement. I can't imagine using a sprayer unless it was a pro version with controlled pattern. - Patience, and lots of it! - Look at all the gripper teeth and make sure they are there (Dart was missing one for some reason). Make sure they are straight, etc. for easy "gripping". - Up to you on this, but I glued foil backed rubber patches across the surface of the roof to help with vibration. Then I glued poly/insulation to help with heat control and additional sound deadening.
I thought I was done, and saw some wrinkles. I did not pull side to side tight enough. Don't be scared of tugging on it a bit. The material will stretch. Anyway, I pulled the sides loose and re-did them.
Sail panel area was the hardest part as you can imagine.
383, Hemi 4-Speed, AlterKtion, D60
Re: Headliner tips
[Re: Crazy68Dart]
#1648555
07/21/14 07:54 AM
07/21/14 07:54 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
all great tips, i will just add, put all screws back in there holes (sunvisor,mirror seatbelts,clothes hanger ,dome light) make a small map with measurements were these screws are, install headliners, then it will be way easier to feel the head of the screws instead of the holes, with a sharp exacto knife cut small x at top of screw head, then back screw out with your screw driver
Re: Headliner tips
[Re: meepmeep70]
#1648556
07/21/14 09:45 AM
07/21/14 09:45 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Great tips!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
