B-body rear tires #164798
12/09/08 09:39 AM
12/09/08 09:39 AM
rochester michigan, oakland co...
drmonday Offline OP
drmonday  Offline OP
Will 275/60/15 tires on 15/8 magnum wheels fit on the rear of a 68 b-body with stock suspension without any interference, clearance problems or bottoming out?
Re: B-body rear tires [Re: drmonday] #164799
12/09/08 12:53 PM
12/09/08 12:53 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Back spacing is the thing to look at. If you have 3 1/2 to 4 in back spacing you should be OK. That size should net an 11 inch section or so.
Re: B-body rear tires [Re: drmonday] #164800
12/09/08 01:36 PM
12/09/08 01:36 PM
Witness Protection Program
Kudakidd Online boogie
Kudakidd  Online Boogie
Had that size tire on my 68 Charger. Plenty o' room.
Re: B-body rear tires [Re: drmonday] #164801
12/09/08 01:54 PM
12/09/08 01:54 PM
Colorado
CaptainGTX Offline
CaptainGTX  Offline
Colorado
I currently have the same tire/wheel combo on my 69 GTX with no interference.
Re: B-body rear tires [Re: Kudakidd] #164802
12/09/08 03:32 PM
12/09/08 03:32 PM
drmonday Offline OP
drmonday  Offline OP
Thanks, What did you put on the front 235's?
Re: B-body rear tires [Re: CaptainGTX] #164803
12/09/08 03:34 PM
12/09/08 03:34 PM
drmonday Offline OP
drmonday  Offline OP
Thanks, What did you put on the front?
Re: B-body rear tires [Re: drmonday] #164804
12/09/08 08:32 PM
12/09/08 08:32 PM
on my Charger I had 215/70-15 for a bit of that 'big and little' look. The front rims were 15x7's and the rears were 15x8-1/2"
Re: B-body rear tires [Re: drmonday] #164805
12/09/08 10:33 PM
12/09/08 10:33 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Thats what are on my dads 68 gtx vert. no problems
Re: B-body rear tires [Re: drmonday] #164806
12/10/08 11:52 AM
12/10/08 11:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yup
Re: B-body rear tires [Re: Mr.Yuck] #164807
12/10/08 02:24 PM
12/10/08 02:24 PM
Kent, WA
triple_green Offline
Kent, WA
Largest you can go on the front with guarenteed no problems is 15x7 with 4" backspace and 235x60x15 tires.
Some are running larger, but some have problems with anything larger.
68 Charger, 383 HP console auto, spring green, stock restoration
Re: B-body rear tires [Re: triple_green] #164808
12/10/08 02:41 PM
12/10/08 02:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
A big bluky tire up front would look funny. I use 215/75/15's or a 225/70/15 up front and 275/60/15's out back.
Re: B-body rear tires [Re: triple_green] #164809
12/10/08 03:20 PM
12/10/08 03:20 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
I'm running 15x8(4 1/2" backspace) magnums w/265-50-15s on the front and 15x10(5" backspace) magnums w/295-50-15s on the rear. No problems on my 68 charger. Scatpk has a similar setup and I believe he said he had run 395-50-15 drag radials under his GTX w/ no problems,D.
Re: B-body rear tires [Re: bigD] #164810
12/10/08 03:40 PM
12/10/08 03:40 PM
Kent, WA
Kent, WA
"I'm running 15x8(4 1/2 offset) magnums w/265-50-15s on the front and 15x10(5"offset) magnums w/295-50-15s on the rear. No problems on my 68 charger,D."
Can't be at stock "ride height".
Air shocks and tortion bar cranked up---maybe.
3X
Re: B-body rear tires [Re: triple_green] #164811
12/10/08 05:09 PM
12/10/08 05:09 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
The rear has Hd springs(R/T)and the front is actually lowered,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: B-body rear tires [Re: drmonday] #164812
12/10/08 05:34 PM
12/10/08 05:34 PM
CHRGR69 Offline
CHRGR69  Offline
295/50 15's on 15x10 on my 69 Charger with room to spare!
Grandma always said I had "hands of gold"!
Re: B-body rear tires [Re: drmonday] #164813
12/10/08 08:21 PM
12/10/08 08:21 PM
Colorado
CaptainGTX Offline
CaptainGTX  Offline
Colorado
Have 225/70R15's on 15X7 Magnums on front to go with 275/60R15's on 15X8 Magnums on rear on my 69 GTX. Outside diameters are about the same & I (and others) think they look great. Got everything from Coker as a package deal.
Re: B-body rear tires [Re: Kudakidd] #164814
12/11/08 10:17 AM
12/11/08 10:17 AM
drmonday Offline OP
drmonday  Offline OP
Thanks everyone for the feedback! Its great information!
