Struck out on dakota, scored this instead #1648088
07/19/14 01:00 AM
07/19/14 01:00 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Couldn't find a dakota r/t in my price range that wasn't killed but i found this 69 valiant here on the classifieds. Ended up being 40 miles away and a great deal.
Car has:
69 383 4bbl, 727, 3:23sg, 16:1 ff manual box, manual kh discs and a recent front end rebuild(ball joints, tie rods, torsion bars)still has small bolt pattern setup. Has front 225/60 rear 245/60r14 bfgs
Goal is street/strip/autox and some day down the line some track events. Once i get all the driveability/electrical bugs worked out what are the best bang for the buck upgrades? Planning subframe connectors when i have the floors patched this winter.
Thanks for any advice!
Chris
Re: Struck out on dakota, scored this instead [Re: buconine] #1648089
07/19/14 01:07 AM
07/19/14 01:07 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
some autocross classes and organizations don't allow for the sub frame connectors to be welded to the actual floorboards of the car, only the ends to the sub frames. be sure to do your research.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Struck out on dakota, scored this instead [Re: amxautox] #1648090
07/19/14 01:28 AM
07/19/14 01:28 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I was going to try for the cam class. I don't know how competitive it would be in street prepared. Really need to talk to the local region guys and see where the car fits.
Re: Struck out on dakota, scored this instead [Re: buconine] #1648091
07/19/14 01:46 AM
07/19/14 01:46 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We made enough mods to my son's Barracuda that, even though it was street driven, we had to compete in CP (otherwise known as Heavy Metal). We couldn't compete with truly prepared cars, but did well against the entire field which included some "popular" autocross cars. We were running a 383/4sp in a 67 Barracuda...
Re: Struck out on dakota, scored this instead [Re: buconine] #1648092
07/19/14 02:43 AM
07/19/14 02:43 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I've seen a couple videos of Jim's son's Barracuda from way back when and it handled pretty well. As for upgrades, if it were me, I'd probably add larger T-bars (at least 1.06"), get 17 or 18" wheels and tires (Coy's make a set and Motech sells Show Wheels in sbp), and a good pair of shocks (Bilsteins or Fox).
Re: Struck out on dakota, scored this instead [Re: buconine] #1648093
07/19/14 09:07 PM
07/19/14 09:07 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
We'll since CAM was created for this kind of car, I wouldn't hesitate, I just built my 67 to run CAM and finished 2nd out of 12 cars in its debut (.4 sec away from first...). Start with a front Swaybar and some sticky 200 treadware tires and go have fun!
Re: Struck out on dakota, scored this instead [Re: Tomswheels] #1648094
07/19/14 10:30 PM
07/19/14 10:30 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Got front tires on it today so i could finally take it for a shake down run. Amazing how much better it drove without a slipped belt on the front. Need to figure out why it won't upshift into third next. I'm assuming the kickdown linkage is binding/out of adjustment.
Are there any bolt on sway bars for our cars?
Any interior restrictions in cam? Front bench is shot and thought i would throw some aftermarket seats in it if i didn't move me to a higher class.
Thanks for the info. Can't wait to get the bugs out of this thing at take it to the races next month.
Re: Struck out on dakota, scored this instead [Re: buconine] #1648095
07/19/14 10:54 PM
07/19/14 10:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You have some good bones to work with there! There are several Valiant builds you can check out to learn what parts and combos others have done well with.
Re: Struck out on dakota, scored this instead [Re: buconine] #1648096
07/19/14 11:23 PM
07/19/14 11:23 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Plenty of bolt on Sway Bar options, again, I'd start with front only, then good 200 treadwear tires, then shocks. The only interior restriction in CAM is that you have to have one, so seats that keep you centered are a great idea. CAM allows any mods, as long as you are over 3000 lbs, have all exterior body panels and an interior, and use 200 or higher treadwear tires. Similar to the Goodguys Autocross rules, very lenient to a lot of mods!
Re: Struck out on dakota, scored this instead [Re: ScottSmith_Harms] #1648097
07/19/14 11:32 PM
07/19/14 11:32 PM
IN
ahy Offline
ahy  Offline
IN
There are plenty of choices for sway bars. I worked with Firm Feel on my stuff.
If/when you think of upgrade to BBP wheels it would be a good time to upgrade brakes. The KH work fine but are hard/a bit expensive to service. Late A spindles, 11.75 rotors and matching calipers would be a good upgrade and easily serviced (see Mopar Action Diskotech).
Re: Struck out on dakota, scored this instead [Re: ahy] #1648098
07/20/14 12:09 AM
07/20/14 12:09 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
would a sway bar for the current suspension work with the newer suspension?
I'm going to have to run the current setup for awhile and add little things while i build up funds. I can see the next step steamrolling into a big expense. bbp front/rear and wheels/tires is going to be pricey but worth every penny in the long run.
Re: Struck out on dakota, scored this instead [Re: ScottSmith_Harms] #1648099
07/20/14 12:23 AM
07/20/14 12:23 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Need a really poorly done six pack hood for a 68 valiant? Need to find a correct year hood for mine eventually.
Love the red brick. I was actually reading the thread on your car when i found my 69. Beautiful car, best of luck with it!
Re: Struck out on dakota, scored this instead [Re: buconine] #1648100
07/20/14 05:24 AM
07/20/14 05:24 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Not upshifting to 3rd could be just the gearshift linkage not being adjusted properly with the shifter. I would start by checking this first.
Nice little car.
Re: Struck out on dakota, scored this instead [Re: BigBlockMopar] #1648101
07/20/14 02:22 PM
07/20/14 02:22 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Congrats, I've always liked that style of Valiant. I was looking for one of those when I bought my 74 Dart, but I just couldn't find one.
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Struck out on dakota, scored this instead [Re: Sneke_Eyez] #1648102
07/20/14 02:26 PM
07/20/14 02:26 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
Build the car the way you want and run CAM. We created the class for folks like you.
Dave Dusterberg
1979 Aspen R/T (soon to be #19 CAM/T)
2002 Ram 1500 SLT
2005 Magnum R/T
2005 Mustang GT SCCA CAM/C #19
Re: Struck out on dakota, scored this instead [Re: IndyDave] #1648103
07/20/14 03:44 PM
07/20/14 03:44 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Curious question about CAM, with its liberal rule set, why no alcohol or alcohol/water injection allowed?
Water injection is my plan for avoiding detonation without going to the widely variable and sometimes unavailable E85 solution for high compression.
Re: Struck out on dakota, scored this instead [Re: IndyDave] #1648104
07/20/14 05:54 PM
07/20/14 05:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would say you hit a home run with that little sweetheart. Also a testament to me needing to check freakin Craiglist more!
Mopar to the bone!!!
Re: Struck out on dakota, scored this instead [Re: TC@HP2] #1648105
07/20/14 06:32 PM
07/20/14 06:32 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
I don't know where you got that? Right now it's not addressed specifically in the rules as to what you can use but since the cars are to street legal, licensed and insured, most regions would default to the fuel rules for Street, and Street Touring rules which say that it must be a fuel federally approved for highway use on public highways.
Dave Dusterberg
2002 Ram 1500 SLT
2005 Magnum R/T
Re: Struck out on dakota, scored this instead [Re: IndyDave] #1648106
07/20/14 08:52 PM
07/20/14 08:52 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Found it on here, at the bottom of the page under safety:
http://www.solomatters.com/introducing-classic-american-muscle-cam
Have to admit, I'm not an SCCA member, have not researched this further than a quick google, and until my car hits the pavement, I likely won't be attending any of their events. I do see they have a few cars running CAM in my region, Rocky Mtn, so it is available when I decide to go, but if the h2o injection eliminates me as a competitor, then I will only be running for experience
Re: Struck out on dakota, scored this instead [Re: TC@HP2] #1648107
07/20/14 09:14 PM
07/20/14 09:14 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
OK, that's from the General Regulations in the Solo Rulebook. Took me a while to find it. Those rules apply to all SCCA Solo classes. My guess why that rule is in place is due to fire concerns. SCCA Solo events are generally run without emergency equipment on scene. We do have basic safety equipment with us, firefighting equipment is limited to ABC extinguishers. While many of us are trained in the proper use of fire extinguishers putting out an alcohol fire can be tricky. Gasoline fires can be seen, alcohol fires cannot always.
Dave Dusterberg
2002 Ram 1500 SLT
2005 Magnum R/T
