ok- a how to- A body hood hinge springs?? #1648042
07/18/14 11:36 PM
07/18/14 11:36 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
How the hell do I get the hood springs off the hinges? Got a fiberglass hood and need some low tension springs but can't seem to get the old ones off the post. Please help...
Re: ok- a how to- A body hood hinge springs?? [Re: BEEQUIK] #1648043
07/19/14 12:00 AM
07/19/14 12:00 AM
Andrewh Offline
Andrewh  Offline
you open the hood to expand the spring.
then stuff cardboard into the gaps.
close the hood a bit and the spring stays expanded.
you can use coins too, but I like the extra depth of cardboard.
or just anything not compressable.
Re: ok- a how to- A body hood hinge springs?? [Re: Andrewh] #1648044
07/19/14 12:05 AM
07/19/14 12:05 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
I forgot to mention the hinges are off the car.no way to expand the springs.
Re: ok- a how to- A body hood hinge springs?? [Re: BEEQUIK] #1648045
07/19/14 01:55 AM
07/19/14 01:55 AM
Andrewh Offline
Andrewh  Offline
same concept but more work.
you will need shims instead. so they are tapered and lets you wedge them between the coils.
go to home depot and pick up a couple of packs of wooden shims. just start working them between the coils to pull it apart.
Re: ok- a how to- A body hood hinge springs?? [Re: BEEQUIK] #1648046
07/19/14 03:33 AM
07/19/14 03:33 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I think Andrew is thinking of coil springs.
If the hinge is off the car already, clamp it in a vice. Using a small pry bar (or other suitable tool), pry the hooked end of the spring off the pin. Just be careful.
The pin at the center of the spring is peened to keep it from sliding off. Using a small cutoff wheel, you can cut/grind the the peen until the spring will slide off the pin. It won't take much.
After the new spring is installed I just put a little spot weld (blob) where the peening was removed on the pin to keep the spring from sliding off.
Then, it's pretty easy to grab the hook end of the spring with some channel-lock pliers and hook it over the outer pin.
Re: ok- a how to- A body hood hinge springs?? [Re: 70Duster440] #1648047
07/19/14 02:21 PM
07/19/14 02:21 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
This is how you do it. Clearence the center peen first, then clamp the spring and remove the hook part and slide it all up and out.
Re: ok- a how to- A body hood hinge springs?? [Re: Sport440] #1648048
07/19/14 04:14 PM
07/19/14 04:14 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Thanks! grinding off the center peen was the part I wasnt sure of . I am getting some low tension springs for my new fiberglass hood setup. Love the blown duster! I am building a blown dart currently.
Re: ok- a how to- A body hood hinge springs?? [Re: BEEQUIK] #1648049
07/19/14 07:35 PM
07/19/14 07:35 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Here's what I do.Clamp the hinge in a vice,very tight,and use the open end of a crescent wrench to hook on the spring hook.Pull it off,very easy,.You can also put it back on this way after restoration.
