Re: What Amp Alternator?
[Re: Hem1orange]
#1647586
07/17/14 07:18 PM
07/17/14 07:18 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I put a Tuff Stuff OEM replacement 100 amp alternator on my street and strip Duster due to the current draw of the race fuel pump and MSD 7 sereis ignition and so on. I figure it is way better to have alternator that will have room for future growth if I decided to add other electric parts onto the system later. I bought a 100 amp Powermaster single wire GM type for my race car, I ran a #8 wire form the alternator directly back to the + side of the battery and added a analog Volt meter inside to make sure it was charging while running The race car has a electric water pump, electric fan, electric fuel pump, race ignition, electric delay box, two big batterys and so on The race car has none of the original wiring so it was simple to add that #8 wire to the battery
[Re: rapom]
#1647589
07/17/14 08:51 PM
07/17/14 08:51 PM
Posts: 397 Colorado
Hem1orange
Colorado
If you have an atomic efi I would use a delco alt from powermaster. About 94 amps at idle max and 140amps highway. If you have and electric fuel pump, fan, A/C you need the extra cushion.
Thanks, That will work. Can I use the original brackets with this alternator or do I have too modify anything?
Ron
[Re: Hem1orange]
#1647590
07/17/14 10:18 PM
07/17/14 10:18 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I used brackets from http://bouchillonperformance.com/inc/sdetail/467/571 Their kit uses the stock brackets. Stock brackets work with a different spacer. I didn't use the belt routing that they show. I have the a/c belt going directly to the crank pulley and the water pump and power steering sharing the same belt instead of the way they show. By the way, I'm also using the atomic msd so if you need any tips I might be able to help you.
[Re: Hem1orange]
#1647595
07/17/14 11:00 PM
07/17/14 11:00 PM
Posts: 5,448 So Cal
Sinitro
So Cal
If U are going to up the alternator capability, suggest U go through the entire electrical system... The Mopar 68 OE system uses connectors, terminals that can only handle 25-35 AMPS @ max. One of the 1st areas needing upgrading are the bulkhead connectors, also revise the AMP guage to one for Voltage.. Think through the entire electrical system, are U going to be adding other higher current draw accessories such as electronics, subwoofer amplifier, electric fans. Just my $0.05...
[Re: Sinitro]
#1647596
07/17/14 11:35 PM
07/17/14 11:35 PM
Posts: 397 Colorado
Hem1orange
Colorado
If U are going to up the alternator capability, suggest U go through the entire electrical system... Just my $0.05...
Good Thought!
I went though everything except the amp gauge. I plan to use relays where I can.
Thanks Ron
Fire Bad!
[Re: rapom]
#1647598
07/18/14 08:17 PM
07/18/14 08:17 PM
Posts: 7,664 IN
ahy
IN
Agree... with the EFI Fuel pump and electronics idle output of any of the squareback options would be low. The Powermaster/Delco or 120A Denso would work well. As posted above you will need one of the bulkhead bypass strategies. An alternator as above would fry the stock wiring in short order. On my setup, I ran 6 gauge wire + 10 gauge fusible link from the alternator output to the fender relay... and added a voltmeter to keep track of system condition.
[Re: Hem1orange]
#1647600
07/19/14 10:35 AM
07/19/14 10:35 AM
rapom
Northern OH
Looks like you have a nice 68 charger project. I also have a 68 charger (69 fenders) with an updated electrical system. I put in a painless system and I can tell you it wasn't painless to install. I put a toyota alt.(denso) in this car.
