E brake routing with rame connectors #1647544
07/17/14 02:53 PM
07/17/14 02:53 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
I know I have seen it here before so can anybody give me some ideas about routing my e brake cables through the frame connectors?
Re: E brake routing with rame connectors [Re: rhamson] #1647545
07/17/14 04:56 PM
07/17/14 04:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: E brake routing with rame connectors [Re: gtx6970] #1647546
07/17/14 04:57 PM
07/17/14 04:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2
Re: E brake routing with rame connectors [Re: gtx6970] #1647547
07/17/14 04:57 PM
07/17/14 04:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
3
Re: E brake routing with rame connectors [Re: gtx6970] #1647548
07/17/14 04:58 PM
07/17/14 04:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: E brake routing with rame connectors [Re: gtx6970] #1647549
07/17/14 04:59 PM
07/17/14 04:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The outside of the frame connector just has a 1/2" ID bronze sleeve held in with JB weld. Been almost 3 years like this and no problems what so ever
Re: E brake routing with rame connectors [Re: gtx6970] #1647550
07/17/14 05:00 PM
07/17/14 05:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
pass side.
It's just a GM ( cough,cough) Battery J bolt
Re: E brake routing with rame connectors [Re: gtx6970] #1647551
07/18/14 02:34 PM
07/18/14 02:34 PM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Did you slot this into the frame connector so that the travel of the piece would not be restricted? I ask this because I have seen others that just brought a tube through the connector and everything was outside of it.
Thanks for the information.
Re: E brake routing with rame connectors [Re: rhamson] #1647552
07/19/14 02:03 AM
07/19/14 02:03 AM
MI
chapdog105 Offline
chapdog105  Offline
MI
Here's my 69 Plymouth Roadrunner convertible with US Car Tool frame connectors.
Re: E brake routing with rame connectors [Re: rhamson] #1647553
07/19/14 10:53 AM
07/19/14 10:53 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Correct. the location of the connector ( a 1/2" in either direction side to side ) and length of the cable are factors if you do or don't have to slot the connector. I wanted no issues no matter how hard the cars owner pushed on the emer brake pedal. There for I slotted it.
Re: E brake routing with rame connectors [Re: rhamson] #1647554
07/19/14 02:03 PM
07/19/14 02:03 PM
Wisconsin
Mopar_Mudder Offline
Wisconsin
Here is another thread with pictures of mine and others in it.
E-Brake
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: E brake routing with rame connectors [Re: Mopar_Mudder] #1647555
07/21/14 10:48 AM
07/21/14 10:48 AM
Maryland
rhamson Offline OP
rhamson  Offline OP
Maryland
Thank you for all the information. I was wondering about any exhaust interference but I found you did address it. Thanks again.
