spray bar oiling #1646963
07/15/14 03:19 PM
07/15/14 03:19 PM
ca
brownout Offline OP
brownout  Offline OP
ca
Ok So I am interested in getting a set of individual shaft rockers (t&d)for my original b1 heads. Is spray bar oiling through the valve covers going to be enough for the primary source of oiling to the pushrod cups and rockers? valve spring pressures from 300-350 on the seat and up to 850-900 open at the most. This is going to be a turbo motor and will probably see 8,000 to 8,500 rpm at the highest. Thing is I don't want to pay to have the lifter bores to be bushed and I already have a set of new crane lifters. Right now I have the common shaft t&d setup should I just stick with this?
Thanks, Cody
Re: spray bar oiling [Re: brownout] #1646964
07/15/14 03:25 PM
07/15/14 03:25 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
My B1 499 has both pushrod oiling and spray bar. They got the oil for the spray bars from the side of the block. When I put in the 440-1 540 (also has pushrod oiling) I think I will use the spray bar oiling valve covers on it too. Why not? 2 seperate oil sources and the springs get a little cooling.
The pushrod oil supplies the needle on the shaft and also for the rollers on the T&D.
Edit: I was looking at the valve covers last night. The spray bar is over the pushrods/rockers and I have no idea how that would help as the adjusters are sockets and shrouded by the 1.7 T&D rockers.
Re: spray bar oiling [Re: brownout] #1646965
07/15/14 04:41 PM
07/15/14 04:41 PM
AndyF Offline
AndyF  Offline
Maybe, maybe not. I had several people tell me that spray bar oiling would work just fine for my Jesel setup but we started to see burned up pushrods after just a few dyno pulls. I added pushrod oiling and haven't had any problems since.
Re: spray bar oiling [Re: AndyF] #1646966
07/15/14 04:46 PM
07/15/14 04:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use spray bar oiling on all our Indy heads with the Jesel rockers with no problems,
Re: spray bar oiling [Re: B G Racing] #1646967
07/15/14 05:07 PM
07/15/14 05:07 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I think that the turbo might have something to say here. It puts a lot of stress on the exhaust pushrods that I believe might lead you to burning some up. Just a thought.
Todd
Re: spray bar oiling [Re: brownout] #1646968
07/15/14 09:16 PM
07/15/14 09:16 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
My .....with B1s and turbo, I'd be wanting pushrod oiling as well. Spraying the springs does provide oiling to the pushrod to some degree, but nothing like a dedicated oil thru pushrod or shaft pressurized oiling. I'd be more comfortable knowing the valve spring are staying cool with the spray bar, and the B1s are oiling the cups with pushrods or shafts.. B1s like and need the oiling in my opinion.
RIP Monte Smith
Re: spray bar oiling [Re: CompWedgeEngines] #1646969
07/16/14 02:47 AM
07/16/14 02:47 AM
ca
brownout Offline OP
brownout  Offline OP
ca
yeah this is kind of what I expected to hear. Think there is any issues with just running the t&d common shaft rockers that I have and oiling through the shaft. I am sure people have ran them at that open pressure and beyond but are they reliable?
thanks for the info and experience everyone.
Re: spray bar oiling [Re: brownout] #1646970
07/16/14 01:41 PM
07/16/14 01:41 PM
ca
brownout Offline OP
brownout  Offline OP
ca
Anybody with experience and lots of run time with the common shaft t and d rockers for the b1 heads?
Re: spray bar oiling [Re: brownout] #1646971
07/16/14 02:29 PM
07/16/14 02:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've got T&D common shaft rockers on my W-2s but I
went with the short shafts on my B1 M/C heads.. I never
ran it though and sold it... but the common shafts on
the W-2s worked fine with just the stock oiling(up
thru the head)... ran them for years like that.. I
did change over to push rod oiling on my 416 when I
put the W-2s on it.. and I plugged the head oil ports
Re: spray bar oiling [Re: MR_P_BODY] #1646972
07/16/14 02:40 PM
07/16/14 02:40 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm a fan of pushrod oiling, can't think of a reason to need both.
Re: spray bar oiling [Re: camastomcat] #1646973
07/16/14 02:51 PM
07/16/14 02:51 PM
ca
brownout Offline OP
brownout  Offline OP
ca
Thanks I understand it's either pushrod oiling or through the shaft. Just wondering if people experiences with the common shaft setup like mr pbodys. Thanks and what spring pressure did you run with you w-2 setup
Re: spray bar oiling [Re: brownout] #1646974
07/16/14 03:07 PM
07/16/14 03:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Roller cam and seat is 270# and 680# open.. I run
T&Ds on all of my engines but only have the common shaft
on the W-2s.. my W-9 has the short shafts and I run
325# seat and just short of 900# open.. never had
any issue with any T&D breaking or anything like that
Re: spray bar oiling [Re: camastomcat] #1646975
07/16/14 04:07 PM
07/16/14 04:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO the common shaft stuff is ok to a point. When you get into those kind of spring pressure I don't think I would go that way for sure. I have used common shaft stuff with open pressure around 850 not sure I would want to go further than that. From my experience anything above that and you will start to see issues with breakage. While I do not have any first hand experience I have seen it on a number of other combos. When you throw in the turbo think then IMO you need to go with the best possible parts and methods. The added pressure/heat on the exhaust side would want me to go wit paired shaft set up and pushrod oiling. IMO the only thing spray bars are good for is valvespring cooling and some added life there. Not to use as a primary method of oiling a pushrod cup.
Re: spray bar oiling [Re: Al_Alguire] #1646976
07/16/14 05:41 PM
07/16/14 05:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself.. I would never use the spray bars as the
means of oiling the rockers and push rods.. to me
its too hard to get the oil in the rocker and shaft..
it would only gets what might drip in... granted the
T&D rockers use needle bearings on the shaft and dont
require much oil to keep them happy... this is just
my opinion but the spray bars work great for cooling
the springs... the T&D rockers I have, have a hole
going both directions from the shaft(the common shaft)
and the oil drips off the roller tip and down the
springs to carry heat away then the other hole oils
the push rod tips and runs down the push rod... I
dont know what kind of spring pressure he will be
running with the turbo set up but on the common shaft
system you have just the 5 bolts(3/8" grade 8) but
have a farther span between the bolts vs the 3 bolts
per pair on the short shaft system and they are right
next to the rocker..... just something to think about..
here's a pic of the short shaft style
Re: spray bar oiling [Re: MR_P_BODY] #1646977
07/17/14 02:13 PM
07/17/14 02:13 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have run the Spray Bar oiling systems on all of my engines with ZERO problems.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: spray bar oiling [Re: MRMOPAR622] #1646978
07/19/14 10:17 AM
07/19/14 10:17 AM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
12 years for me with spray bar oiling on 572-13 heads ,t&d rockers ,800+spring presure and alot of street use as well. Oh and 1200 + passes at the track
Re: spray bar oiling [Re: avenger572] #1646979
07/19/14 11:22 AM
07/19/14 11:22 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The spray bars provide plenty of oil and the rocker movement throws it everywhere.Needle bearing rockers on short shafts are like roller lifters and can live with mist lubercation.With the spray under pressure and movement the entire valve train becomes saturated with oil.With any common shaft we would recommend through shaft oiling.thumb:
Re: spray bar oiling [Re: B G Racing] #1646980
07/19/14 11:25 AM
07/19/14 11:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob... I'm gonna sent you a PM on some parts
Re: spray bar oiling [Re: brownout] #1646981
07/19/14 12:12 PM
07/19/14 12:12 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
First off , you are starting a turbo build and you say the words "don't want to pay for " LOL
1- Take what ever you think your going spend and double it .
2- leave the engine alone until the end , the engine is the easiest part of the build .
3- Mount the bare engine and heads and buy the turbo stuff to start fabrication , ( turbo , gates , charge tube , hot and cold side exhaust )don't buy a single engine internal until you are pretty much done the fab work on the car ( cage , rear end , transmittion )
4- take a picture of how much hair and what color it is before and after the build.
Don't do spray bar oiling , its just a silly way to oil anything . Push rod oiling is worth the money and is obviously far superior to spray , anyone who says otherwise is not correct .Valve train is the one department that should have no compromise for quality and reliability . I just spent about $9000 for my valve train , reliability comes at a cost .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: spray bar oiling [Re: brownout] #1646982
07/19/14 01:23 PM
07/19/14 01:23 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ryan J used to call it "spray and pray", but i'v been doin it on my 408 for the last 9 yrs without issue. my program is much smaller than yours thou at 600hp n/a level and 600# open pressure. some track and many street miles.
