Re: Bring back the shine on a Carter AFB or Eddy Performer?
[Re: JohnRR]
#1646529
07/14/14 06:32 PM
07/14/14 06:32 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Its been so long since I bought the Carter AFB Competition Series that I must have forgotten. I thought I remembered it being shiny when I took it out of the box.
OK then, how about making the Eddys shine again than.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: BigBlockMopar]
#1646531
07/14/14 09:32 PM
07/14/14 09:32 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
WD40 and a set of these brushes and elbow grease. All these carbs are aluminum but some Eddy's had a "Ball Burnished" finish that when new shined like chrome. Simply polished aluminum. These brushes can be found at home depot paint dept. They can reach the tight spots but for 4 carbs get at least 6 sets of brushes. They wear out quick. $4 a set I believe. A Hoppes pistol cleaning rod w/ .45 cal, .38 cal and .223 brushes also come in handy for the passages, and Hoppes powder solvent will break out any gum/bs and smell good too!
[Re: Pynzo]
#1646532
07/14/14 10:47 PM
07/14/14 10:47 PM
hp383
State of Confusion
I love the smell of the Hoppes. I sometimes dab some on a paper towel and use it as air freshener.
[Re: hp383]
#1646533
07/14/14 10:55 PM
07/14/14 10:55 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: Pynzo]
#1646535
07/14/14 11:19 PM
07/14/14 11:19 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Once had my newly ceramic coated TTI headers almost destroyed by a substantial rear main seal leak and had almost 200 miles that I had to drive before able to resolve leak.
Coated with oil on collectors that baked on like the worst oven you had ever seen. Used these steel and brass brushes using Flitz and Mothers aluminum polishes.
Headers came out perfect with no apparent damage,,,,did take a few hours of scrubbing however. I have before and after photos if anyone cares to see.
[Re: hp383]
#1646537
07/15/14 01:33 PM
07/15/14 01:33 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Yes, there were Competition series Carters with a shiny finish.,...your not going crazy....
RIP Monte Smith
[Re: Pynzo]
#1646538
07/15/14 03:46 PM
07/15/14 03:46 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
on the use of bore brushes. Worked a treat on my badly stored AVS
[Re: RSNOMO]
#1646541
07/15/14 05:12 PM
07/15/14 05:12 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I was on the fence initially...
But I'll tell ya'...
Got one on top of a 440...
It's been there 15+ years...
With very minimal effort, it still looks new...
I'm a believer...
I prefer the factory look and they don't look factory to me.
