Radiator transmission cooler / auto vs four speed #1646391
07/14/14 10:45 AM
07/14/14 10:45 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I had a discussion with someone on Saturday regarding the transmission cooler in the bottom tank of a radiator.
I say that all radiators, regardless of whether they are in an automatic or four speed equipped car, had an internal cooler in the bottom tank. The fours speed cars would have plugs screwed into the ports of the un-used cooler.
My friend says that only the automatic cars had the radiator with the cooler and that the bottom tank on a four speed car did not even have the provision for the cooler.
Which is correct?
Thanks.
Stan
Re: Radiator transmission cooler / auto vs four speed [Re: HemiStan] #1646392
07/14/14 12:05 PM
07/14/14 12:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Your friend is wrong !!
Re: Radiator transmission cooler / auto vs four speed [Re: 62maxwgn] #1646393
07/14/14 12:15 PM
07/14/14 12:15 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
My OEM 26" had plugs in the cooler tank holes. Transfered them over to a junkyard radiator I picked up long ago.
Re: Radiator transmission cooler / auto vs four speed [Re: Pynzo] #1646394
07/14/14 01:11 PM
07/14/14 01:11 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the clarification! I appreciate it.
Stan
Re: Radiator transmission cooler / auto vs four speed [Re: HemiStan] #1646395
07/14/14 03:20 PM
07/14/14 03:20 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Correct that both 4 speed and auto had coolers on the bottom, but not all 4 speeds tanks had plugs, depending on model and year.
Here is a 1968 Dart, Barracuda 340 4 speed bottom tank that is 4 speed only, no automatic line provisions.
Re: Radiator transmission cooler / auto vs four speed [Re: mccannix] #1646396
07/14/14 03:21 PM
07/14/14 03:21 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
In the books 2898026 is 68 manual only 340 Dart Barracuda rad.
Re: Radiator transmission cooler / auto vs four speed [Re: mccannix] #1646397
07/16/14 06:31 PM
07/16/14 06:31 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
For 1970 and 1971 rads the following applies:
26" rads all have the tranny cooler on them, regardless of transmission type.
22" rads, the manual trans ones have no cooler or holes in the bottom tank for them. The automatics all do.
19" rads, the same applies as for 22" rads.
Re: Radiator transmission cooler / auto vs four speed [Re: m46rat] #1646398
07/16/14 07:33 PM
07/16/14 07:33 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
mccannix and m46rat,
Very good info. I did not know that.
Thanks.
Stan
