1970 B Body Steering Column #1646370
07/14/14 09:34 AM
07/14/14 09:34 AM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Hello I am in the midst of tearing down my 1970 Dodge Charger steering column. It is an auto on the column shifter type. My question is how do you remove the flange near the upper part of the shaft. Or is it removable at all? I've attached pics with my situation. Please view all pics (4).
Thanks in advance.
Re: 1970 B Body Steering Column [Re: VegasCharger] #1646371
07/14/14 09:35 AM
07/14/14 09:35 AM
Akron, Ohio
Akron, Ohio
pic #2
Re: 1970 B Body Steering Column [Re: VegasCharger] #1646372
07/14/14 09:35 AM
07/14/14 09:35 AM
Akron, Ohio
Akron, Ohio
pic #3
Re: 1970 B Body Steering Column [Re: VegasCharger] #1646373
07/14/14 09:36 AM
07/14/14 09:36 AM
Akron, Ohio
Akron, Ohio
pic #4
Re: 1970 B Body Steering Column [Re: VegasCharger] #1646374
07/14/14 11:32 AM
07/14/14 11:32 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
yes , were your yellow arrows pointing carefully slide that collar up to expose the pin underneath, drive it out and you got it...pat
Re: 1970 B Body Steering Column [Re: pattyboy 572] #1646375
07/14/14 11:20 PM
07/14/14 11:20 PM
Akron, Ohio
Akron, Ohio
Thanks Pat that did the trick!!!
It's amazing how much you work on things and then you stumble across a head scratcher. Something so simple yet hidden from your eyes. I didn't want to just start pounding on things not knowing what was going to happen and cause potential damage.
Thanks again
Re: 1970 B Body Steering Column [Re: VegasCharger] #1646376
07/14/14 11:32 PM
07/14/14 11:32 PM
new york usa
P
P
new york usa
Glad to have helped , I believe the procedure is in the (f s m) factory service manual. wait till you do a 1968 a little more interesting
Re: 1970 B Body Steering Column [Re: pattyboy 572] #1646377
07/15/14 08:18 AM
07/15/14 08:18 AM
Akron, Ohio
Akron, Ohio
Thanks again Pat, sent you a PM
